Page 6 of 55 1 2 4 5 6 7 8 54 55
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061133
10/31/11 05:49 PM
10/31/11 05:49 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Oh yea, I forgot your's was a YJ.
Oh well
Careful, your character's showing!
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061134
10/31/11 08:06 PM
10/31/11 08:06 PM
Tampa
DusterDave Offline OP
Tampa
Oh well
That's OK, I appreciate the thought. I did some 'net searching, and I found a blueprint of a YJ frame.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061135
10/31/11 08:28 PM
10/31/11 08:28 PM
mopar346 Offline
mopar346  Offline
Thanks, I added that to my file just in case. But it's in milometers, not sure I have a tape for that.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061136
10/31/11 09:00 PM
10/31/11 09:00 PM
Tampa
Tampa
Me neither. Divide them by 25.4 to convert to inches.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061137
11/06/11 12:46 PM
11/06/11 12:46 PM
Tampa
Tampa
Made a bit of progress on the frame work. First, I got the frame and skid plate back from the sand blasters. They did a fantastic job removing every spec of rust, even on the inside of the frame as far as they could reach. Fortunately, there was very little rust inside the frame to begin with. The nasty finish you see on it was from the Ospho I sprayed as soon as I got it home, to prevent flash rust.
I finished cutting all of the segments to build one frame rail. I made a drawing in Autocad to get my dimensions of all of the frame segments.
I used my new Milwaukee chop saw to cut the segments. I laid the segments over the old frame rail, and it follows the shape and angles perfectly, so I'll use these pieces to trace out the ones for the other side.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061138
11/06/11 01:16 PM
11/06/11 01:16 PM
Tampa
Tampa
I made some decisions on steering and suspension. I decided to mount the springs over the axle (SOA), and use Rubicon Express 1.5" lift SOA springs, with 6 leaf packs up front and 5 leaf packs in the rear. The 6 up front is to compensate for the all iron 390" engine. For steering, I decided to go with a high steer setup. So, I purchased new high steer knuckles from partsmike.com. Its a complete kit, and he upgraded it with 2" forged steering arms at no extra charge. Shown in this pic are the standard flat arms.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061139
11/06/11 04:36 PM
11/06/11 04:36 PM
Lehigh Acres, Florida
rickstershemi Offline
Very nice work and great parts choices IMO
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061140
11/07/11 08:12 PM
11/07/11 08:12 PM
Tampa
Tampa
Rickster
Thanks, Rick!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061141
11/13/11 11:53 PM
11/13/11 11:53 PM
Tampa
Tampa
My high steer kit came in. The steering arms are forged and very beefy. They will easily clear the leaf springs.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061142
11/13/11 11:55 PM
11/13/11 11:55 PM
WOW.....BIG
Rickster
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061143
11/13/11 11:57 PM
11/13/11 11:57 PM
Tampa
Tampa
I made some progress on the frame work.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061144
11/14/11 12:00 AM
11/14/11 12:00 AM
Nice Work Dave
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061145
11/14/11 12:11 AM
11/14/11 12:11 AM
Tampa
Tampa
WOW.....BIG
Rickster
Can you say BOMB PROOF?
Right after Thanksgiving, I'm going to drop off both axles at the local shop called Allen's Gearworks to get them re-geared (4.55's), install the lockers, Warn hubs, and replace worn parts.
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061146
11/14/11 12:14 AM
11/14/11 12:14 AM
Tampa
Tampa
Thanks, Rick! I'll be a better welder when this project is finished.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061147
11/14/11 01:27 AM
11/14/11 01:27 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....lurking. I love the fact you spit out such cool crap out of that "shop"
Re: MY JEEP BUILD THREAD [Re: J_BODY] #1061148
11/14/11 11:02 PM
11/14/11 11:02 PM
Tampa
Tampa
Thanks, J-Body. It keeps me out of trouble, and my wife never has to wonder where I'm at.
I made the other rail today. I messed up on the angle on the last segment of the rail in the foreground. I'll need to cut and re-weld it.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061149
11/16/11 12:33 AM
11/16/11 12:33 AM
Tampa
Tampa
Fixed it.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061150
11/20/11 08:05 PM
11/20/11 08:05 PM
Tampa
Tampa
I've reached the first of many milestones in this project. The frame rebuild is complete. Since the rear bumper mounting bracket was in decent shape, I reused it. It was helpful in verifying some dimensions. I measured everything 6 ways to Sunday from many body and suspension mounting points, and its all dead nuts.
The next phase is to send the Dana 44's to the axle shop to get rebuilt, re-geared with 4.56's, Warn hubs, and locker diffs installed.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061151
11/20/11 09:21 PM
11/20/11 09:21 PM
Sweet
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061152
11/21/11 12:44 AM
11/21/11 12:44 AM
mopar346 Offline
mopar346  Offline
Very impressive, you are coming along nicely.
Here is what I built yesterday, gonna get the bars bent for the rear section tomorrow and tack them in. Then I'll take it to a real welder to do the final welding, I don't trust my self on cages.
