440 intake holes too far apart to bolt up? #1061000
08/24/11 12:38 PM
08/24/11 12:38 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i am putting a 6 pack intake onto a 440 , using napa gaskets and valley pan. when i put the gaskets and valley pan on i cant get the intake to line up with the holes, the intake seems to wide . with out the gaskets and valley pan the holes will line up.
would the gaskets be too thick or does it sound like someone may have milled the block or heads?
i tried several times to get it to bolt up and i can only ever get one side of the bolts in but then the other side looks at least 1/8 off from working.
any advice?
Re: 440 intake holes too far apart to bolt up? [Re: dirt] #1061001
08/24/11 12:41 PM
08/24/11 12:41 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Are you using the valley tray AND the paper gaskets ? If using paper gaskets also how many? Have you tried to install just using the valley tray?
Re: 440 intake holes too far apart to bolt up? [Re: JohnRR] #1061002
08/24/11 12:44 PM
08/24/11 12:44 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i was using the valley tray and gaskets also. there is 4 gaskets all together. is that the way it should be or do some people not use the paper gaskets?
Re: 440 intake holes too far apart to bolt up? [Re: dirt] #1061003
08/24/11 12:51 PM
08/24/11 12:51 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I never use the paper gaskets and it works just fine
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 440 intake holes too far apart to bolt up? [Re: MOPARMIKE69] #1061004
08/24/11 12:54 PM
08/24/11 12:54 PM
upstate NY
batt2rm Offline
batt2rm  Offline
upstate NY
same here never use gaskets
Re: 440 intake holes too far apart to bolt up? [Re: dirt] #1061005
08/24/11 01:51 PM
08/24/11 01:51 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Doing it with the tin makes it very easy to reuse that tin gasket.
Re: 440 intake holes too far apart to bolt up? [Re: batt2rm] #1061006
08/24/11 01:53 PM
08/24/11 01:53 PM
Yes alot of times it will not fit w the supplied gaskets and those gaskets ain't cut perfect enough to suit me. Install it WO them & tho people have installed valley pans dry w no reported probs I dont think the metal is pliable enough to seal perfect on each port & I use a light coat of Permatex #1 in the toothpaste like tube SPARINGLY but evenly around each port opening/both sides of the valley & a bit on the bolt threads.
Re: 440 intake holes too far apart to bolt up? [Re: RapidRobert] #1061007
08/24/11 01:57 PM
08/24/11 01:57 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Another vote for no paper gaskets. They didn't come with them from the factory - don't need them later.
Re: 440 intake holes too far apart to bolt up? [Re: MoparforLife] #1061008
08/24/11 02:23 PM
08/24/11 02:23 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i tried it with just the valley pan and i still cannot get the bolts in the holes but it is very close. the only way the bolts will go in is with our anything between the intake and heads and even then they barely line up close enough to go in.
i am starting to think that something was milled on the motor.
Re: 440 intake holes too far apart to bolt up? [Re: dirt] #1061009
08/24/11 02:28 PM
08/24/11 02:28 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
sounds like it.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 440 intake holes too far apart to bolt up? [Re: dirt] #1061010
08/24/11 02:31 PM
08/24/11 02:31 PM
in that case you'll want to mill the intake. Normally you'd mill the heads' intake faces so the intake wou'dn't b specific to that eng but the short block is already assembled
Re: 440 intake holes too far apart to bolt up? [Re: dirt] #1061011
08/24/11 02:46 PM
08/24/11 02:46 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Especially on aluminum intakes/aftermarket , i let the intake mounting dictate on whether to use gaskets or not on the valley pan
Just ask the guys that didnt , wondering why there sucking oil under the valley pan
EVERY INTAKE IS DIFFERENT
Peace
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 440 intake holes too far apart to bolt up? [Re: bee1971] #1061012
08/24/11 03:20 PM
08/24/11 03:20 PM
Upper Midwest
Upper Midwest
If the holes are as close as you say - Take and elongate them slightly When the intake is pulled down into place when the bolts are tightened the mismatch would be negligible and performance wise unnoticeable. Been down that road and the difference didn't even show up on a time clock.
Re: 440 intake holes too far apart to bolt up? [Re: MoparforLife] #1061013
08/24/11 03:27 PM
08/24/11 03:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
edelbrock 6-pak intakes are too wide. the last one i bought i had to cut .040 off each side to get it to line up. another one i have has .090 off each side for the use of paper gaskets.
Re: 440 intake holes too far apart to bolt up? [Re: GwaiiEagle] #1061014
08/24/11 03:28 PM
08/24/11 03:28 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Another just the tin.Been doing them for 45 years like that and no problems.Rocky
Chrysler Firepower
Re: 440 intake holes too far apart to bolt up? [Re: dirt] #1061015
08/24/11 03:40 PM
08/24/11 03:40 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The special thin "paper" gaskets that I have always used are super thin and come in a 4-pack. Regular common parts store "paper" intake type intake gaskets are too thick to use, especially when you have 2 per side.
Your heads or block may have been surfaced enough to affect it too. If that's the case, you will need to have your intake surfaced as already stated.
I've often found that once I can get a few bolts per side started, the intake compresses down enough to install the rest of the bolds. Like was mentioned above, you may have to elongate the bolt holes slightly to get a couple to start. One time I started one side and used a prybar to lever down the other side by carefully using the heat crossover gap to gently push the intake down on the free side, so I could start the bolts.
I alway like to make sure to use a quality gasket sealer (Permatex Ultra Seal) making sure to put a good sized dab at the corners or the head /valley pan and smear a very thin coat on the remaining surfaces.
My latest motor uses a different set-up, but still requires a little coaxing to get the intake down enough to start the bolts.
Re: 440 intake holes too far apart to bolt up? [Re: dirt] #1061016
08/24/11 03:44 PM
08/24/11 03:44 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Just use the pan and start the 4 bolts on one side, then use the shaft of a decent size phillips screwdriver in 4 remaining holes to pry intake over a little to start bolts on that side of intake. That should help immensely. If not, you might be getting intake shaved.
Re: 440 intake holes too far apart to bolt up? [Re: MoparforLife] #1061017
08/24/11 06:54 PM
08/24/11 06:54 PM
ill
dennismopar73 Offline
ill
first off, sound like the block been decked,
secound , i know some have gotten by with the plain o metal,
hurah for you, !! i never have with aluminum intake ,
i always put the intake on dry, get my feeler gauge out check fron to
back , side to side, dont ever tr to just grind the hole open and make it fit,
reminds me of a commercial , 2 guys putting a battery in a car thats to big , and they are holding a hammer ,," we can make it fit"
i use the fiber, cut away the metal small amount of sealer, im done . no leaks, !
Re: 440 intake holes too far apart to bolt up? [Re: MoparforLife] #1061018
08/25/11 09:37 AM
08/25/11 09:37 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
If the holes are as close as you say - Take and elongate them slightly...
Re: 440 intake holes too far apart to bolt up? [Re: Commando1] #1061019
08/25/11 09:44 AM
08/25/11 09:44 AM
JohnRR Offline
JohnRR  Offline
