Re: 440 intake holes too far apart to bolt up?
[Re: dirt]
#1061003
08/24/11 12:51 PM
08/24/11 12:51 PM
Posts: 2,637 Nashville, TN
MOPARMIKE69
Nashville, TN
I never use the paper gaskets and it works just fine
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: dirt]
#1061005
08/24/11 01:51 PM
08/24/11 01:51 PM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
Doing it with the tin makes it very easy to reuse that tin gasket.
[Re: batt2rm]
#1061006
08/24/11 01:53 PM
08/24/11 01:53 PM
RapidRobert
Yes alot of times it will not fit w the supplied gaskets and those gaskets ain't cut perfect enough to suit me. Install it WO them & tho people have installed valley pans dry w no reported probs I dont think the metal is pliable enough to seal perfect on each port & I use a light coat of Permatex #1 in the toothpaste like tube SPARINGLY but evenly around each port opening/both sides of the valley & a bit on the bolt threads.
[Re: dirt]
#1061010
08/24/11 02:31 PM
08/24/11 02:31 PM
RapidRobert
in that case you'll want to mill the intake. Normally you'd mill the heads' intake faces so the intake wou'dn't b specific to that eng but the short block is already assembled
[Re: dirt]
#1061011
08/24/11 02:46 PM
08/24/11 02:46 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Especially on aluminum intakes/aftermarket , i let the intake mounting dictate on whether to use gaskets or not on the valley pan
Just ask the guys that didnt , wondering why there sucking oil under the valley pan
EVERY INTAKE IS DIFFERENT
Peace
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: GwaiiEagle]
#1061014
08/24/11 03:28 PM
08/24/11 03:28 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Another just the tin.Been doing them for 45 years like that and no problems.Rocky
Chrysler Firepower
[Re: dirt]
#1061015
08/24/11 03:40 PM
08/24/11 03:40 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
The special thin "paper" gaskets that I have always used are super thin and come in a 4-pack. Regular common parts store "paper" intake type intake gaskets are too thick to use, especially when you have 2 per side.
Your heads or block may have been surfaced enough to affect it too. If that's the case, you will need to have your intake surfaced as already stated.
I've often found that once I can get a few bolts per side started, the intake compresses down enough to install the rest of the bolds. Like was mentioned above, you may have to elongate the bolt holes slightly to get a couple to start. One time I started one side and used a prybar to lever down the other side by carefully using the heat crossover gap to gently push the intake down on the free side, so I could start the bolts.
I alway like to make sure to use a quality gasket sealer (Permatex Ultra Seal) making sure to put a good sized dab at the corners or the head /valley pan and smear a very thin coat on the remaining surfaces.
My latest motor uses a different set-up, but still requires a little coaxing to get the intake down enough to start the bolts.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: MoparforLife]
#1061017
08/24/11 06:54 PM
08/24/11 06:54 PM
Posts: 2,177 ill
dennismopar73
ill
first off, sound like the block been decked, secound , i know some have gotten by with the plain o metal, hurah for you, !! i never have with aluminum intake , i always put the intake on dry, get my feeler gauge out check fron to back , side to side, dont ever tr to just grind the hole open and make it fit, reminds me of a commercial , 2 guys putting a battery in a car thats to big , and they are holding a hammer ,," we can make it fit" i use the fiber, cut away the metal small amount of sealer, im done . no leaks, ! ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
