Possible to run low 8s with cal tracks and 10,5 tire? #1060975
08/24/11 12:33 PM
08/24/11 12:33 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Is it possible or is it a stretch?
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: domingo] #1060976
08/24/11 12:58 PM
08/24/11 12:58 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: GomangoCuda] #1060977
08/24/11 01:00 PM
08/24/11 01:00 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
7.22
wow!
I have 33 x 10,5 slicks on 10" wheels.
I think those outlaw guys run wider wheels and beadlocks?
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: domingo] #1060978
08/24/11 01:32 PM
08/24/11 01:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Several guys out here have done it...............
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: Thumperdart] #1060979
08/24/11 02:11 PM
08/24/11 02:11 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Do you guys think 33 x 10,5" is a good tire or is it a tad too tall causing the car to be unstable at higher speeds?
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: domingo] #1060980
08/24/11 02:51 PM
08/24/11 02:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have a wing or enough down force on the back
of the car the tires would be fine(would give you a
larger foot print)
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: domingo] #1060981
08/24/11 04:06 PM
08/24/11 04:06 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
caltrac's easy to hold 8's..getting everything else correct take some doing..my buds do it all the stock susp cars..but u need to tinker thats for sure
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: fishy340] #1060982
08/24/11 04:39 PM
08/24/11 04:39 PM
Guitar Jones Offline
Is it possible? Sure. Do it consistently? No.
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: Guitar Jones] #1060983
08/24/11 05:44 PM
08/24/11 05:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This is "somewhat" of a true statement. A buddy of mine ran solid 8.20`s-8.40`s in a 400+in. chevy on a fogger and drag radials but when the track wasn`t there or he had nos issues, he`d go high 9`s-low 10`s.
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: Thumperdart] #1060984
08/24/11 06:11 PM
08/24/11 06:11 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Its not that hard of a task at all.....
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: joshking440] #1060985
08/24/11 06:40 PM
08/24/11 06:40 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
It's been done with Mopar but generally you have to build for a shorter front spring segment.
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: Leon441] #1060986
08/24/11 06:41 PM
08/24/11 06:41 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
dont you mean a longer front spring segment Leon
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: joshking440] #1060987
08/25/11 09:58 AM
08/25/11 09:58 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: racerx] #1060988
08/25/11 11:51 AM
08/25/11 11:51 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Talk to guppy (demongup) he has been in the 7s with his demon and has won 3 or 4 8.50 index races here. I would have to say his car is really consisent and is mini tubbed, cal tracs, and 10 in tire. So yes it is very possible.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: domingo] #1060989
08/25/11 12:21 PM
08/25/11 12:21 PM
gregsdart Online content
gregsdart  Online Content
Start on the high side of recommended tire pressure for safety. You are on the narrow side for rims, and they become unstable faster (lower pressure) Than a wide rim combo.
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: gregsdart] #1060990
08/25/11 01:04 PM
08/25/11 01:04 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Right....
And if running 10,5 tires on wider rims....do you need to run beadlocks?
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: domingo] #1060991
08/26/11 12:20 AM
08/26/11 12:20 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: domingo] #1060992
08/26/11 08:56 AM
08/26/11 08:56 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I intend to get into the 8's with torsion bars & cal trac's.The black brick weighs in at a lightwight 3850 with me & fuel in the car.Rear tires will be 10.5 W or 13X31.The cert is good to 8.50,any faster than that I'm in trouble
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: hemi-itis] #1060993
08/26/11 02:07 PM
08/26/11 02:07 PM
pa
572charger Offline
572charger  Offline
pa
ive been there on s/s springs 8.98 at 154mph at 3910lbs on sheetz 93 octane
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Possible to run low 8s with cal tracks and 10,5 tire? [Re: 572charger] #1060994
08/26/11 02:34 PM
08/26/11 02:34 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
ive been 8s with caltracs torsion bars stock a arms on a 275.....
