Is it possible to run two Tachs at the same time? #106081
08/16/08 08:32 PM
08/16/08 08:32 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
I suspect the Sun tach (looks to be somewhat old) in my 1970 Coronet is not reading accurately at higher RPMs. "Feels" like it's ok at idle or low RPMs. I've heard that some older tach have problems with Mopar electronic ignition, so I'm not sure if this is a factor.
I was wondering if it would be possible to have two tachs running a car simultaneously?? From what I remember, a tach gets it's info from the negative side of the coil, right? If I had another tach and powered it from the right source and added it's wire to the one from the Sun tach at the coil now, would that work?
Thanks a lot!
--Stan
Re: Is it possible to run two Tachs at the same time? [Re: stan1970] #106082
08/16/08 08:37 PM
08/16/08 08:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't see why it wouldn't work.
Re: Is it possible to run two Tachs at the same time? [Re: stumpy] #106083
08/16/08 08:44 PM
08/16/08 08:44 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
yes i have , tic toc tach and a stewart warner , but with points .
Re: Is it possible to run two Tachs at the same time? [Re: JohnRR] #106084
08/16/08 08:51 PM
08/16/08 08:51 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
I've run a factory tach and Dixco tach at the same with points and also with electronic ignition.
Re: Is it possible to run two Tachs at the same time? [Re: JohnRR] #106085
08/16/08 08:51 PM
08/16/08 08:51 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I've seen factory and aftermarket tach running together many times. 2 aftermarket ones can't see why not but I've never seen it.
Do you have a timing light with a tach?
Re: Is it possible to run two Tachs at the same time? [Re: Magnum] #106086
08/16/08 10:21 PM
08/16/08 10:21 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Thanks all for your answers!
Regarding Timing light -- I just have a basic one -- no tach on it.
I suspect my old Sun tach is not accurate at higher RPMs, so wanted to hook up another to verify before yanking it out and discarding it. When I take off in the car (4speed w/ 4.10 gears in the rear), it feels like it's revving very high and I have to shift, but generally the tach is showing less than 2000 RPMs. So, I figured that can't be right..
So, it sounds like I can have two wires going to the negative side of the coil for the two tachs. I was just thinking that somehow they might interfere with each other, but it sounds like a lot of folks run this way already.
Thanks !
Re: Is it possible to run two Tachs at the same time? [Re: stan1970] #106087
08/16/08 10:46 PM
08/16/08 10:46 PM
Castlegar, BC, Canada
That AMC Guy Offline
Tone Generators are great for this kind of thing. Every pulse sensing tach can be re-set correctly using a pulse generator.
Believe it or not, anybody with an audio editing program and a line out jack can create their own tone generator Very helpful when recalibrating old tachs.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Is it possible to run two Tachs at the same time? [Re: That AMC Guy] #106088
08/16/08 10:55 PM
08/16/08 10:55 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Yes, it will work fine.
Re: Is it possible to run two Tachs at the same time? [Re: That AMC Guy] #106089
08/16/08 11:01 PM
08/16/08 11:01 PM
(Ahem...) My age is showing. In the mid '60's I build an Allied Radio "Knight kit" tach, and they had you calibrate it using a high value resistor off the AC line as a pulse source. Nowadays, that would be a gigantic liability.
I would suspect that if you hooked ENOUGH tachs up all the same time, you'll eventally load down the ignition, but I doubt two of 'em will do it
Re: Is it possible to run two Tachs at the same time? #106090
08/16/08 11:05 PM
08/16/08 11:05 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I have one in my dash for driving and one under the hood of my Duster for tuning, both wired to my MSD's tach terminal.
Ride eternal, shiny and chrome
Re: Is it possible to run two Tachs at the same time? [Re: stan1970] #106091
08/17/08 01:14 PM
08/17/08 01:14 PM
Upstate, NY
sixpack4spd Online content
sixpack4spd  Online Content
Upstate, NY
What does the tach say when you are going 70MPH in 4th gear???
Re: Is it possible to run two Tachs at the same time? [Re: sixpack4spd] #106092
08/17/08 02:48 PM
08/17/08 02:48 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Just add the extra one in and splice it in to the feed lines of the old tach. Will work fine.
Re: Is it possible to run two Tachs at the same time? [Re: sixpack4spd] #106093
08/18/08 12:25 PM
08/18/08 12:25 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Thanks all for the help!
sixpack4spd - it shows under 3k RPMs in 4th gear at around that speed... which I don't think can be right...
Re: Is it possible to run two Tachs at the same time? [Re: stan1970] #106094
08/18/08 12:43 PM
08/18/08 12:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Punch your #s in here and see what you get. http://vexer.com/68rt/speed.html
Figure your tire diameter here. http://www.procomptires.com/conversionchart.htm
Re: Is it possible to run two Tachs at the same time? [Re: DaytonaTurbo] #106095
08/18/08 12:58 PM
08/18/08 12:58 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I just ran into the same question a few months back when I went to install a shift light which has a tach too.
I called the manufacturer and was told I could wire it in w/o any affect. Seems to work fine.
Re: Is it possible to run two Tachs at the same time? [Re: stan1970] #106096
08/18/08 01:37 PM
08/18/08 01:37 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Sun Tachs from the 60's all used a tach adapter box. I don't know what happens if you try to use them without the box. probably doesn't work at all. Chances are your tach isn't that old and it is just bad.
As already stated by several others there is No problem hooking up two tachs.
Re: Is it possible to run two Tachs at the same time? [Re: cruzin] #106097
08/18/08 07:55 PM
08/18/08 07:55 PM
Here
Here
I actually have two tachs and two shift lights wired up.
