Page 2 of 6 1 2 3 4 5 6
Re: SB Oil Pump. Anyone ever done this? [Re: Guitar Jones] #1060545
08/24/11 05:58 AM
08/24/11 05:58 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Aftermarket pans are designed to run oil at a lower level to reduce windage. If you put 9 quarts in a 7 quart pan you running your oil at a higher level than what the pan manufacturer intended not matter what the stick you throw away on a race engine says.LOL
Leon
Re: SB Oil Pump. Anyone ever done this? [Re: Leon441] #1060546
08/24/11 07:25 AM
08/24/11 07:25 AM
Guitar Jones Offline
Yeah, I realize that, I was just saying. Anyway, I'm not worried about making every last little horsepower, I'm more interested in longevity.
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: SB Oil Pump. Anyone ever done this? [Re: Mopar-Al] #1060547
08/24/11 08:03 AM
08/24/11 08:03 AM
Muncie
Racebuddy Offline OP
Muncie
Haven't ever tried the two pick ups yet.
Don't know about pan getting sucked dry...this block had oiling mods done to it. orifices drilled out, large deep chamfer to the crank, balanced bottom end , all new parts.
Have built new motors with high dollar pans and waste the bearings in them in no time. I know alot of the little tricks to helping the SB live butstill, its up to GOD if they live.
Re: SB Oil Pump. Anyone ever done this? [Re: Guitar Jones] #1060548
08/24/11 08:03 AM
08/24/11 08:03 AM
PA
moparacer Offline
moparacer  Offline
PA
If its a stock truck pan. Thats your problem.
I have ran and seen regular old run of the mill Milodon and Moroso center sump pans run into the 9s with a stock pump with the usual mods.
I had a 88 Dakota pickup with a truck pan on it. Run it into the 11s with no problems but after I got into the 10s and eventually 9s there was no way that would have worked with no baffles.
I also have ran rear sump pans on my dragsters and had oil control problems in the shut down.
Are you watching your oil pressure gauge after you lift at the finish?
I bet its dropping or going to zero.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: SB Oil Pump. Anyone ever done this? [Re: moparacer] #1060549
08/24/11 08:28 AM
08/24/11 08:28 AM
Muncie
Muncie
Hadn't got to see the finish line yet with this motor. I take that back, maybe 3 passes.
Chevy is all rear sump pans and they go all day long. So the baffle helps keep it from running dry in the shut down ?
We just saw oil pressure changes after the second run, when it started i'm not sure.
To be honest, clearances were checked by eyeball and feel.
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060550
08/24/11 08:33 AM
08/24/11 08:33 AM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
I would start here.....
Re: SB Oil Pump. Anyone ever done this? [Re: abodiesonly1] #1060551
08/24/11 08:44 AM
08/24/11 08:44 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Sounds like you have built a lot of engines off your eyeball and feel. I think ya need, and I mean NEED to get some mics, and bore guages and check things out.
I am running a precision pump thats blueprinted, and polished inside. My block it opened up on all the oil galleys, Ive spent hours with a diegrinder, and a flap wheel blending all my return holes, I have painted the inside with glyptol to aid in returning oil, have screens epoxied in the valley to keep any broken parts from going down farther than I like, and I have made sure all my clearances are dead on, not close, but dead on what my machinist recomended for the oil I run.
I run a charlies 9 qt pan, and with 9qts in it it still reads 1 qt low. I dont run it brimmed off, and I have never had an oil psi issue. If anything im a bit on the high side, but at temp its reading 85 on higher rpm, and 30 at idle.
Im a solid roller set up, and I have pleanty of oil to my rockers and pushrod cups.
Not to sound like a dick, but I think Id be checking my eyes, and feelers, or getting some tools to make sure you didnt miss something.
Kasey
Re: SB Oil Pump. Anyone ever done this? [Re: Moparnut426] #1060552
08/24/11 09:18 AM
08/24/11 09:18 AM
Muncie
Muncie
Mics and bore gauges is what my machine shops are for.
payin good money to ensure stuff is right from the beginning
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060553
08/24/11 09:29 AM
08/24/11 09:29 AM
Moparnut426 Offline
Moparnut426  Offline
Famous last words from many people.
I NEVER trust anyone on their work. I check every rod, every pin bushing, everything with my own measurments. That way the machinist cant say, "you should have checked it"...
This is what pisses me off with some of these posts. You have a history of engine failure, and you dont want to measure things after they are machined. Yes you may have them right on, but ya know then you may have a good GM machinist, and a crappy mopar machinist. Why be a bone head?
Kasey
Re: SB Oil Pump. Anyone ever done this? [Re: Moparnut426] #1060554
08/24/11 10:08 AM
08/24/11 10:08 AM
Canada BC
Steve Barton Offline
Canada BC
Kasey
I.m with you on this one,I deal with a very rep machine shop and on a few occasions I have had to send things back after double checking there work.
Homepage Pic's http://www.bluemelon.com/dodgeman/ Steve. New best 1.40 60' 9.99 Et 132.8 mph
Re: SB Oil Pump. Anyone ever done this? [Re: abodiesonly1] #1060555
08/24/11 02:51 PM
08/24/11 02:51 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yep, the problem has been discovered .
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060556
08/24/11 03:59 PM
08/24/11 03:59 PM
Muncie
Muncie
My thread was to solicit info or opinions about the 2 pick up pump.
If anyone's got thoughts please hollar. All responses appreciated.
My stuff has put me in the winners circle. I've gone 9.70's with a 418. Wouldn't have 30 years of racing to me credit if I was a Jethro Bo Dean
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060557
08/24/11 04:04 PM
08/24/11 04:04 PM
Moparnut426 Offline
Moparnut426  Offline
Then You of all people SHOULD understand where we are comeing from on the aspect of proper measurments, and specs. As for the twin pickup deal, it should work, but as stated you are sucking the pan dry as is with a single pickup, so i dont see the puckup as the issue. Might just get a deeper pan, and more copacity.
Kasey
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060558
08/24/11 04:34 PM
08/24/11 04:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself I would pass on the double pick ups... as
stated, if one sucks air its done... I havent ever
had a problem with a single stock pick up... I do
extend them when I deepen the pans plus I install
baffles in the pan to keep the oil down there instead
of rolling up the back wall or the front on braking
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060559
08/24/11 06:27 PM
08/24/11 06:27 PM
Locomotion Offline
Locomotion  Offline
But how many more times would you have been in the winner's circle and/or possibly gone even faster if your engines would have stayed together for a "reasonable" amount of time? (Not to mention how much money you could have saved.) Being a good driver or tuner doesn't matter much if the engine doesn't run.
There is probably 300 years of racing and engine building experience in this thread telling you that your problem is solvable without experimenting with "trick" parts. If you have lost a lot of engines in the last 30 years, then you may very well have been doing something wrong. It might be by just a little bit, which would explain why some may not have had problems. But it's that "little bit" one way or the other that will make the difference. Measuring things all but eliminates that variable.
Get all the measurements and clearances checked and get a good baffled pan. What can it hurt?
Re: SB Oil Pump. Anyone ever done this? [Re: Locomotion] #1060560
08/24/11 07:02 PM
08/24/11 07:02 PM
out front
jerrya Offline
Comin to a Labor Day Telethon
jerrya  Offline
out front
How far is the pickup from the bottom of the pan
Man does not plan to fail... he fails to plan
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060561
08/24/11 07:16 PM
08/24/11 07:16 PM
Between a rock & a hard place
cudadoug Online content
cudadoug  Online Content
It's already been said, but I'll repeat it: If the pan goes dry with one pick up, adding another isn't the answer. You have a problem(s) elsewhere. Please consider the constructive critism I'm about to offer. You say the clearances were obtained by "look" (how's that possible) and "feel"...and you also say you've had many that have died due to lack of oil/oil starvation. Me thinks the two might have something in common...
I say that, simply because MANY have screwed together a SBM with common (BAFFLED pan, Melling pump) parts, no or few oiling mods and they have lived normal healthy lives.
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060562
08/24/11 07:34 PM
08/24/11 07:34 PM
Az
Crizila Offline
Crizila  Offline
Az
Two pickups = bad idea and totally unnecessary IMO. You need to look else where for your oiling problems.
Fastest 300
Re: SB Oil Pump. Anyone ever done this? [Re: Racebuddy] #1060563
08/24/11 08:18 PM
08/24/11 08:18 PM
Illinois
colt340 Offline
colt340  Offline
Illinois
The MP engine book shows a kit car pump that had 2 lines going to 1 pickup.
See attach.
6793515-pump.pdf (166 downloads)
Re: SB Oil Pump. Anyone ever done this? [Re: colt340] #1060564
08/24/11 08:57 PM
08/24/11 08:57 PM
FastOne Offline
FastOne  Offline
Might be a good idea to check lifter bore clearances too while you're at it
