So a few years back I rebuild the front end on my Duster using a poly kit from Performance Suspension. So now the car is going to be run as a street/strip car. I ditched the sway bar,instead of cutting the brackets off the lower control arm I did a partial trade for a set of non sway arms.
So,now I'm doing the lowers again.....and now I'm questioning the bushings I bought from Performance Suspension. They don't come with the sleeves. I already pressed out the cups but didn't schuck the shafts. I also bought a set of rubber bushings from Napa. The plan at the moment is to press in the Napa bushings,which include the shell and insert,and then press the rubber out leaving the shell. Then finally install the poly insert and shaft.
I'm not questioning my process. I'm questioning if it's worth all the trouble.....or should I just run the Napa parts?
