Hemi 99 Owners.......Take a look...... #1059608
08/22/11 07:32 PM
08/22/11 07:32 PM
Orange County, Ca.
B1CUDA Offline OP
B1CUDA  Offline OP
Orange County, Ca.
I haven't really had any major issues with this motor(Other than not being able to play with it, as much as I wish I could), since making the decision to go this route, instead of the wedge based stuff. One issue that I have had, is that I have had rocker shaft bolts, completley back out of the stand, obviously resulting in rocker/pushrod damage. It has been as if someone has put a socket on the 12 point head, and backed it out. (I was told to torque these at 25 ft. lbs) Sounds crazy, but, there is no other explanation. Well, after a long phone call today with a very well known Mopar Pro Stock engine builder, I found the problem. I have, apparently, been using the wrong 5/16 12 point bolts for my rocker shafts. Nobody ever said a word to me, mind you, I have had two very well known engine builders put their hands on this motor. In fact, one of these "gurus", put these bolts on it! Apparently the correct bolt to use, is an ARP 2000, that is only available through Jesel. (The new torque spec is 35 foot lbs., for these ARP bolts) I am familiar with the ARP 2000 stuff, as far as rod bolts, etc., but, never knew they made them as little as 5/16. I was able to get a ton of these from this engine builder, as I think he felt sorry for me.
I was told that just about every Hemi 99 motor has, or will have the issue that I was having, as the 170,000 psi 12 points (Whether American or Chinese made) will eventually lose their torque, and back out. From the way he made it sound, he didn't sound too surprised at my dilemma, which is a relief.
Just a little heads up to those of you that have this type of motor, as I would hate to see anyone kill their stuff. I have been very lucky, in the fact that I haven't really damaged anything that bad, but, I would hate to think what it would have been like, if I hadn't found this out.
I don't care what anyone says, Golf is so much easier.
Back to my cave......
Re: Hemi 99 Owners.......Take a look...... [Re: B1CUDA] #1059609
08/22/11 08:06 PM
08/22/11 08:06 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Saweet! I like the Hemi 99 engines, just no familiarity ....Pics would be cool too...
Re: Hemi 99 Owners.......Take a look...... [Re: B1CUDA] #1059610
08/22/11 08:44 PM
08/22/11 08:44 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
That is very good info!! Thanks!
Re: Hemi 99 Owners.......Take a look...... [Re: Dragula] #1059611
08/22/11 08:46 PM
08/22/11 08:46 PM
Orange County, Ca.
B1CUDA Offline OP
B1CUDA  Offline OP
Orange County, Ca.
This is the only pic that I have at my office....
Re: Hemi 99 Owners.......Take a look...... [Re: B1CUDA] #1059612
08/22/11 08:57 PM
08/22/11 08:57 PM
Out West
408strokerdart Offline
Out West
Man, thats alot of engine stuffed in there. I love it!
Re: Hemi 99 Owners.......Take a look...... [Re: B1CUDA] #1059613
08/22/11 09:02 PM
08/22/11 09:02 PM
Delray beach, Florida
P
Performance Only Offline
P
good info, thanks for sharing.
i think it's time you change your name to something more appropriate. "99" Cuda doesn't sound too bad.
machine shop owner and engine builder
Re: Hemi 99 Owners.......Take a look...... [Re: Performance Only] #1059614
08/23/11 09:47 PM
08/23/11 09:47 PM
australia
charger410 Offline
charger410  Offline
australia
I want one
Your car looks mint. How dose it go? and do mind sharing alittle on the engine, drivetrain?
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: Hemi 99 Owners.......Take a look...... [Re: B1CUDA] #1059615
08/23/11 10:25 PM
08/23/11 10:25 PM
Get-X Offline
Get-X  Offline
It looks like this, just has a few more parts bolted on it
Chris, thanks a lot for the heads up! Do these appear to be the correct ones? I got them from Roy so I'm assuming they're probably right.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Hemi 99 Owners.......Take a look...... [Re: Get-X] #1059616
08/23/11 11:59 PM
08/23/11 11:59 PM
back home in georgia ,lake sid...
105630 Offline
105630  Offline
Thanks for that little secret ! hopefully this thing will be coming to life shortly and as long as its taken ,surely don't need no unseen problems coming up .
Re: Hemi 99 Owners.......Take a look...... [Re: 105630] #1059617
08/24/11 12:37 PM
08/24/11 12:37 PM
Orange County, Ca.
B1CUDA Offline OP
B1CUDA  Offline OP
Orange County, Ca.
Get-X - Yes, those look like the correct bolts, but, make sure that they have the ARP stamp on them. (I am referring to the 5/16 rocker shaft bolts) I noticed that you have the 3 bolt stand heads. When you get that thing running, make sure to watch that valvetrain like a hawk. I have heard lots of horror stories, in the way of severe flex & breakage with the 1st & 2nd generation heads (1 bolt & 3 bolt stands)
Hate to sound like "Debbie Downer", but, as stated before, I would hate to see anyone blow their stuff up.
Chris
