Page 1 of 3 1 2 3
Getting sick of the stroker - question about downsize #1059489
08/22/11 04:07 PM
08/22/11 04:07 PM
Maryland
wally426ci Offline OP
Maryland
So i realize that, along with other reasons, I have not driven my 71 Challenger as much since installing a 408 stroker in it about 6 years ago or so.
My car is a 318 car originally and I am thinking of a few options:
a 318 with a bumped up cam to run a 4 barrel
a 340 built to average specs
or use my 360 block with all parts that I can salvage and go back to a "normal" crank with X heads
I am so done with Econo air ports and plan on hopefully running X heads or something similar from pre-71/72 era
I kind of just miss the simple cruise that I get out of my 68 D100 - 318 and sort of get tired of sitting there lumping at red lights. Of course its nice to step on it, but with todays gas prices never coming down, I feel that I'd be just as happy chillin along....
What do you guys think?
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059490
08/22/11 04:13 PM
08/22/11 04:13 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
There is no way I would ever go back to a putter from a stroker.
Install EFI on it. That will help mileage.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059491
08/22/11 04:15 PM
08/22/11 04:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I know what you mean. Both my cars have mostly stock motors except for pistons and heads and cam of course.
After driving a 3000HP dragster for over 10 years, I've had enough performance.
I get off on reliability and driving my cars. Yea they sound good and run good, but are not built for the drag strip anymore.
Why can't you drive your 408 like I do my 340?
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059492
08/22/11 04:16 PM
08/22/11 04:16 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I can understand that. I say 360 block with some magnum heads, maybe with the 1.625/1.925 valves and other streetable components. My MP 360/300hp crate motor idles and drives very nicely but has plenty of torque when you need it.
Facts are stubborn things.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059493
08/22/11 04:40 PM
08/22/11 04:40 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...you're not alone.
i know a lot of guys who run hi hp engines and nearly all say their next build will be mild or stock.
Re: Getting sick of the stroker - question about downsize [Re: can.al] #1059494
08/22/11 04:49 PM
08/22/11 04:49 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I don't know your specs but I run my 408 with a mild cam 228-236* iron ram heads air gap intake and 800 avs carb. Gets 17 mpg with the 5 speed while making 500+ ft lb of torque. Still able to cruise at lower rpm with the A/C and power brakes.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059495
08/22/11 04:52 PM
08/22/11 04:52 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
What cam did you put in your 408?? Everyone tries to push big cams in these strokers. What exhaust do you have.
I putt around town and run errands in my 416. Starts on one pump with a no choke double pumper, a single plane intake, and open element air cleaner. It's got a comp 274S cam. With a dual plane, 750 vac sec, and stock air cleaner it would be even quieter and smoother..
I've got 1500 miles on it since April.
Here's it idling: http://www.youtube.com/watch?v=-8QSTlvdqSs and
Re: Getting sick of the stroker - question about downsize [Re: autoxcuda] #1059496
08/22/11 04:56 PM
08/22/11 04:56 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Recam and detune the stroker. Unless you are running huge compression it's just a bigger cube engine in the long run.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059497
08/22/11 05:30 PM
08/22/11 05:30 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
It's not like 408 is a huge motor. What do I think? I think you're looking at it all wrong; a mild stroker is perfect: good manners and decent power. Change the cam and whatever else you need to to make it more of a mild mannered cruiser.....no need to chop the cubes just to get a mellow ride.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Getting sick of the stroker - question about downsize [Re: DPelletier] #1059498
08/22/11 05:33 PM
08/22/11 05:33 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Maybe you can talk someone into a swap, your 408 and cash for a smaller motor.
-Daty
Re: Getting sick of the stroker - question about downsize [Re: Daty Rogers] #1059499
08/22/11 06:57 PM
08/22/11 06:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
-Daty
Not me, I love my stock bore and stroke 340.
I put Edlebrock heads on it along with lighter 10.5-1 KB pistons and it runs like a stroker, I think. Compared to the 6 or so 340s that I have run before in this car.
It'll go in extreme conditions, hi in the mountains and in the desert heat. We drive it.
Re: Getting sick of the stroker - question about downsize [Re: wally426ci] #1059500
08/22/11 07:15 PM
08/22/11 07:15 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I think you need to go drag race it at strip if you have not ever taken it. It has always been odd to me that people build those pro street beasts that will not race them.
Re: Getting sick of the stroker - question about downsize [Re: Challenger 1] #1059501
08/22/11 07:18 PM
08/22/11 07:18 PM
Texas
Daty Rogers Offline
Daty Rogers  Offline
Texas
Pike's Peak?
-Daty
Re: Getting sick of the stroker - question about downsize [Re: Daty Rogers] #1059502
08/22/11 07:20 PM
08/22/11 07:20 PM
Cincinnati, Ohio
Cincinnati, Ohio
To the OP, you know what made my car reliable with the stock 5/16" fuel lines? Going back to a mechanical fuel pump. Got rid of all the racing fuel pump and filters and now my car run's and never Vapor locks. This was 10+ years ago when I was running straight race gas. Today with the ethanol fuel it would be even worse.
Racing fuel pumps require large inlet sizes which a stock tank struggles with.
Learn to tune the distrubuter with the carb and that makes a huge difference in drivability also. Even with a big cam most can be made street friendly.
Keep the stroker and tune on it first. Good luck.
Pike's Peak?
-Daty
Yes, was there a couple weeks ago. We we're a little closer to heaven.
My little old 340 went right up that huge azz mountain, I tuned for it.
Re: Getting sick of the stroker - question about downsize [Re: Challenger 1] #1059503
08/22/11 09:53 PM
08/22/11 09:53 PM
The most popular engine we build is a 440, KB237's, stock iron heads with stock size plain valves, the SUMMIT 6401 hyd cam ( one of the best street grinds ever made), stock intake, stock stamped rockers--we polish it off with a well tuned distributor, well tuned carb and away it goes! Manifolds or cheap headers and you have an engine that has giant TQ, well over 400 HP and will run like the Ever Ready Bunny! It will MELT tires, tear second gear up and cruise to any spot in the USA with ease. Guys that have them LOVE them! I have built my fair share of big inch inch pump gas monsters and while impressive on the dyno and at the strip it is almost impossible to hook it to the street. The Mopar legend was made with nothing more than that.
My all time favorite is still a 340 4 speed A Body with some gear....so I understand where you are coming from.
Re: Getting sick of the stroker - question about downsize [Re: Challenger 1] #1059504
08/22/11 10:04 PM
08/22/11 10:04 PM
Texas
Daty Rogers Offline
Daty Rogers  Offline
Texas
Pike's Peak?
-Daty
Cool, went up that mountain several years ago on the train, my sister lives up in Florisant (she lives across from the Thunderbird) at 9500 ft. For a flatlander it's tough, really tough. Thanks for the memories.
-Daty
Re: Getting sick of the stroker - question about downsize [Re: ] #1059505
08/22/11 10:06 PM
08/22/11 10:06 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Downsize the cam and convertor. Cheapest way to smooth it out and still have it run good.
I have ridden around in a low budget one with stock edelbrock heads, performer intake, a swap meet 750 afb, and 3:55 gears and it runs 12-teens at over 110mph on narrow street tires. No overheating or anything difficult about it. It uses a lot of gas if you pound on it, but what modified V8 engine doesn't? The owner went from 3:55's to 3:91's out of curiosity and it barely made any difference in et.
Re: Getting sick of the stroker - question about downsize [Re: ] #1059506
08/22/11 10:09 PM
08/22/11 10:09 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have 20,000 miles on my 408, with the comp cams .484 lift 108 lsa cam, 10 to 1, the car has 3.23 rear gear, pump gas diet,well over 100 1/4 mile runs, I would drive that car anywhere. Averages 1.80 60" time,if I put a gear vendors unit in it and it would get better mileage than my jeep liberty.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Getting sick of the stroker - question about downsize [Re: FurryStump] #1059507
08/22/11 10:25 PM
08/22/11 10:25 PM
IN
ahy Offline
ahy  Offline
IN
Agree cubes can be your friend with a street friendly engine. With a milder cam and convertor plus possibly a longer rear gear, 3.23 or more, I bet you would love your stroker as a cruiser. If you post current specs I bet you'll get lots of good suggestions.
Re: Getting sick of the stroker - question about downsize [Re: ahy] #1059508
08/22/11 10:37 PM
08/22/11 10:37 PM
Maryland
Maryland
I'll get some specs together sometime soon. I appreciate all of the responses!!
After all of this time I still have not memorized my cam specs...
I agree that it has alot to do with the converter and cam. I have a permanent exhaust leak too so the heads are 100& gone when I have time and money,
I really need it broken down, checked and get everything documented. I honestly grabbed the block and heads, then the kit and never degreed the cam. I admit that something has to be mismatched. I sit at a red light and it wants to jump slightly even though it has a 2800 stall converter..... Runs great otherwise and has no heat, fuel issues. I probably come down from the 750 edelbrock carb as well.
I like the option of working with what I have for financial purposes. I really need an "engine guy" to go over this puppy in the future and set me straight.
I am running 3:23 suregrip btw.
Page 1 of 3 1 2 3
