I'm planning on a 2-pronged attack. First, treat it with a phosphoric acid based rust converter. Supposed to react with the iron oxide (rust) to convert it to an iron phosphate, releasing the oxygen in the process. Using purple power stuff from local parts stores, sags to spray it in, let it dry. Does not say that it needs neutralized or washed off, says to spray it and leave it. When it's done, the rust turns Black and dries slightly tacky, ready for primer. My second phase is to use zero rust to seal everything. If it's good enough for resto Rick, it's good enough for me!!
Should leave everything "rust free" and sealed to prevent future rust.
