1970 340 manifold heat control / heat riser issue #1058572
08/21/11 01:18 PM
08/21/11 01:18 PM
Manchester, CT
Mitch340duster Offline OP
Manchester, CT
I got the popular repair kit for mine that fits most of the later model small blocks (3683947 off the top of my head).
I was hoping to use this kit along with the larger diameter flap from my 340, but it looks like the press-in bushings that go into the manifold have a smaller outside diameter than the old ones do. The shaft fits into the bushing nice but the bushings arent going to fit into the manifold. Hard to explain the whole situation but there's definitely something weird going on. Anyone ever see this ?
update..NEVER MIND GUYS THANKS ANYHOW....I found a picture from BradsNOS (ugh) that shows the correct kit and it appears the bushings are different. If anyone has them to sell or another suggestion I'm listening. Thanks
Re: 1970 340 manifold heat control / heat riser issue [Re: Mitch340duster] #1058573
08/21/11 08:47 PM
08/21/11 08:47 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I had the bushings turned down on a lath by a friend at a local machine shop. Either that or he made me new ones, I can't remember.
Re: 1970 340 manifold heat control / heat riser issue [Re: Mitch340duster] #1058574
08/21/11 11:10 PM
08/21/11 11:10 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have a NOS SB block kit around I could let it go cheap. The deal is the international shipping and one part missed, the W shaped spring. Will try to grab a pic to show you what I have and if bushing meets your requirement
Re: 1970 340 manifold heat control / heat riser issue [Re: Mitch340duster] #1058575
08/22/11 09:39 AM
08/22/11 09:39 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you have the ID/OD,I have what you need.
Re: 1970 340 manifold heat control / heat riser issue [Re: 62maxwgn] #1058576
08/22/11 02:43 PM
08/22/11 02:43 PM
MO
cdp Offline
cdp  Offline
MO
Is it important that your heat riser work?
Anymore, I just cut out the flapper, weld the holes shut, and weld the counter weight on to look original. None of the cars I own have been driven in cold weather since they were done.
Re: 1970 340 manifold heat control / heat riser issue [Re: cdp] #1058577
08/22/11 04:41 PM
08/22/11 04:41 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Right. My question too. Mine quit working after a few years, and I couldn't tell any difference.
Re: 1970 340 manifold heat control / heat riser issue [Re: kentj340] #1058578
08/23/11 04:58 AM
08/23/11 04:58 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If one still has the heat crossover open and the stock choke setup it does help but if not , especially in the crossover is block , there is no reason to keep it .
Re: 1970 340 manifold heat control / heat riser issue [Re: Mitch340duster] #1058579
08/23/11 12:56 PM
08/23/11 12:56 PM
Manchester, CT
Manchester, CT
Thanks for the help, guys. I'm considering making it non-functional but I'd still like to have the shaft and the weight (maybe leave-out the flapper) and I don't know anyone I can trust to weld cast iron.
Nacho thanks for the offer and I'll keep it in mind if 62max doesnt have the bushings I need, but I'd rather see your kit go to a guy who needs the rest of the stuff too.
62max I'm PM'ing you....
Just info for the rest of you, in addition to the flapper being a larger diameter in the 1970 340, the 1970 uses 2 different size bushings. 1 is larger than the ones included with the 3683947 kit, and 1 is smaller.
Re: 1970 340 manifold heat control / heat riser issue [Re: Mitch340duster] #1058580
08/23/11 01:23 PM
08/23/11 01:23 PM
Manchester, CT
Manchester, CT
62 this is what my weight looks like. Sorry guys I dont know how to attach a file to a PM.
