Spot Welders
#1058179
08/20/11 10:58 PM
08/20/11 10:58 PM
Who has ideas on spot welders that are easy on the wallet but work nicely??
Re: Spot Welders
[Re: 52savoy]
#1058182
08/21/11 08:59 PM
08/21/11 08:59 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
we also have a harbor freight 220 volt does fine. not used often, but , nice to have when needed
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
Re: Spot Welders
[Re: draginmopars]
#1058183
08/21/11 09:11 PM
08/21/11 09:11 PM
Thanks for the input! What do you guys do where you want the appearance of a factory spot but cant fit the tongs? For instance cowls on an E body firewall?
Re: Spot Welders
#1058189
08/22/11 05:13 PM
08/22/11 05:13 PM
OLD318
This depends on what thickness of metal you wish to spot weld and what do you mean by "easy" on the wallet.
The Lenco L-4000 MKII that is referred to here cost almost $1000.00 brand new but its only rated for 20 guage sheet metal and requires a 50 amp single phase plug.
This means that you can certainly get one of these and plug it in at home-(you might need an electrician to setup the plug for you), But this only buys you 20guage spot welding)....
IMHO... The smaller portable types ($400-$750 new) even those which utilize a 230volt 30 amp plug,may work OK with thinner metal 20 guage 22 guage etc. But I don't see how they will work on 18 guage to 18 guage as found on the old mopars...
Others on here will differ on this opinion I'm sure and I'm not trying to start a fight.
I'm just saying I don't see how... etc...
The professional spot welders used by the factory usually (if not always) require 3-phase commercial plugs... You can't get that in a residential setting. (Single phase)... and they generate 1000's of amps to do this correctly.
Whats wrong with MIG Welding?
Re: Spot Welders
[Re: OLD318]
#1058190
08/22/11 05:52 PM
08/22/11 05:52 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Sort of; my larger spot welder is rated at 19,000 amps at the secondary coil, but that translates to a 30 amp 208/3/60 service. My smaller Miller unit takes a 20amp breaker. I don't know what those little ones are rated at, but while the amperage of the welder is part of the equation, we simply adjust the weld time to deal with most thicknesses of sheet metal. I also question whether or not most mopars have 18ga exterior panels.....the few I micrometered didn't; 20-22ga IIRC. I wouldn't trust some hobbiest spot welder on subframes, K frames or the like, but I'm sure most decent ones don't have a problem with outer body panels....course you have to make sure the metal is clean, contact is tight with adequate pressure and the tips are in good shape.... Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: Spot Welders
[Re: DPelletier]
#1058191
08/22/11 06:11 PM
08/22/11 06:11 PM
This is why I posted to get as much info i can before i make a move. Heres what I am hoping to achieve: Spend less than a grand on one. Get a respectable factory appearing weld. (I know it wont ever be that nice original factory spot, but I want to try getting it) Get a little more satisfaction doing it myself without giving up cleanliness and quality that i may or may not get paying someone else to do. I appreciate all input, ideas, and past experiences, its what makes this site great for the hobbyist!
Re: Spot Welders
#1058192
08/22/11 06:18 PM
08/22/11 06:18 PM
DPelletier
Actually, I can easily duplicate a factory spot weld perfectly with either of my machines.
1974 'Cuda
Re: Spot Welders
[Re: dannysbee]
#1058194
08/22/11 08:51 PM
08/22/11 08:51 PM
A flat nosed punch with a dolley. It's a two man job but its cheap.
I was thinking of something like that today, wondering if it would look good. Looked like the metal was crimped in a lot from the factory.
Re: Spot Welders
[Re: DPelletier]
#1058195
08/22/11 10:54 PM
08/22/11 10:54 PM
Posts: 4,253 State of Fascism
52savoy
State of Fascism
I do that easily with the 120V HF welder I go all over(add welds) the body(s) to stiffen it up. Just leave the switch on longer for deeper welds and they are identical to the factory welds.
Re: Spot Welders
[Re: DPelletier]
#1058196
08/23/11 01:57 AM
08/23/11 01:57 AM
Posts: 636 California
sixpaktoogo
California
Dave, What brand of welders are you using? Can you post pictures of your welds? Thanks!
Re: Spot Welders
[Re: 52savoy]
#1058197
08/23/11 01:59 AM
08/23/11 01:59 AM
sixpaktoogo
California
Can you post pictures of your welds and the welder you use? Thanks!
Re: Spot Welders
[Re: sixpaktoogo]
#1058198
08/23/11 02:15 PM
08/23/11 02:15 PM
DPelletier
I have a sheet metal fabrication shop, so mine aren't what most hobbiests would have access to. I have a Western Arctronics 30KVA and a Miller 20FT. The Miller is convertable to portable duty, the Western is not. If you still want pics, let me know.
1974 'Cuda
