Page 28 of 31 1 2 26 27 28 29 30 31
Re: Design me a late model Hemi bracket engine [Re: mshred] #1057449
03/29/12 11:46 PM
03/29/12 11:46 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
talked to kent this mourning he said anyone interested in the intake can call him @585-610-9979 his cell or mike wear @ muscel motors for any info or to order one, later guys
there a price on this thing yet for the public?
Also, I would be hours looking through this whole thread again, but I could swear someone had the part number for a complete longblock (or shortblock?) 5.7 or 6.1 (or both) from the dealer. Is this still so? are they available? or would someone need a VIN to get one?
Sorry forgot to put this in P5155437.
Re: Design me a late model Hemi bracket engine [Re: MattW] #1057450
05/14/12 03:08 PM
05/14/12 03:08 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
We have a few early 5.7 engines with low miles on them. We just scored a set of Eagle heads for one of them. I figure I'm running 10.90's with a fairly mild 5.9 magnum motor with a 4" crank and box stock Iron Ram heads. The 5.7 eagle headed motor with a decent hyd roller cam, DP intake and TTI headers should put me back in the same numbers using the stock rotating assembly with a hone and rering shouldn't it? I'm gonna try it.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Design me a late model Hemi bracket engine [Re: StandOnIt] #1057451
08/09/12 06:08 PM
08/09/12 06:08 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Design me a late model Hemi bracket engine [Re: 65signet] #1057452
08/09/12 06:47 PM
08/09/12 06:47 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
X2 What happened to this thread? Everybody quit building, or just quit giving out info.. I KNOW info is hard to get FREE!!
If you like drag racing, support your local track.
Re: Design me a late model Hemi bracket engine [Re: CHAPPER] #1057453
08/09/12 08:21 PM
08/09/12 08:21 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nope I'm building my R3 4.25 stroke Indy 230 CNC head engines. I have my head in the sand.
But since I have everything to put my R3 together it was a no brainer.
Still working on the G3 but gathering info. Like to know if the oiling issue is fact or fiction?
There is rumor of a 6.2 litre G3 supercharge engine coming out. Would like to get the block specs on that one. Me THINKS they would drop the bore to increase the wall strength. Matt
Re: Design me a late model Hemi bracket engine [Re: MattW] #1057454
08/10/12 08:41 AM
08/10/12 08:41 AM
NY usa
540challenger Offline
NY usa
Well after changing my build to include the MP alum. block i tapped out the funds. Also since looking at the power level i might be pushing i decided to do the rest of the metal work on my challenger an cage so i don't twist that car. Then i have to wait for Matt to get his build done first, So i can make sure i run .001 faster then him.
Re: Design me a late model Hemi bracket engine [Re: 540challenger] #1057455
08/10/12 02:22 PM
08/10/12 02:22 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
If u wait for me ill be in a pine box.
I was already to go full bore on my car since the wife ok'd it.
Now I maybe going on strike at the end of the year. I really don't think we are going.
It will depend on what the teachers do Aug 28.
They will set the tone for the rest of Ontario government.
If we dont go out, this time next year I'm hoping to be driving my paper weight.
If you really want to be faster than me borrow your kids tricycle.
Re: Design me a late model Hemi bracket engine [Re: MattW] #1057456
08/10/12 02:46 PM
08/10/12 02:46 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I am considering building a 3G for a Duster and would need to run 9.50s all out, and the car would be used to race in super gas, and other index racing. i just want make sure these will work and last. what size motor would work and what heads,comp....
Re: Design me a late model Hemi bracket engine [Re: Irun5snd8th] #1057457
08/20/12 11:13 AM
08/20/12 11:13 AM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
Just a bump so this thread doesn't get lost. A lot of good info here!
Re: Design me a late model Hemi bracket engine [Re: 65signet] #1057458
08/20/12 05:09 PM
08/20/12 05:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I talked to Arrington a while back
They offered a 426 inch motor with a 267/271 hydralic roller, drag pack intake, at about 12 to 1 compression complete that they said would make an honest 650 ponies.
A motor nearly identical to this is installed( shop car they have on website) in a new body style charger that i believe has gone 10.20s ish at around 4000 pounds, but i think has a bit less compression( dont quote me on that)
Based on that, i suspect a 3000 pound A body should runs mid 9's carburated without a lot of trouble once sorted out.
Motor complete was 13 grand ish as i recall.This included an optional setup that mounted coil packs on the intake.
Basically an assembled longblock with intake and coil packs, and using they're trick rocker gear, and fully ported heads they supply, custom crank rods and pistons.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Design me a late model Hemi bracket engine [Re: B3422W5] #1057459
08/20/12 09:28 PM
08/20/12 09:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Its all in the heads. they flow so much with so little effort.
You have Eddies coming out with a victor aluminum head don't know what date.
You have INDY with all their customer service and quality products and even with all this you will need serious effort RE $$$$$$$$$$ to get the flow numbers any where near the ported G3 head
I will be building one in the future but for now since I have all the parts my R3 is going together. Once completed and my car is running, the G3 starts.
Still trying to figure out what the oiling issue is, if there is any
For now Its R3 time.
Re: Design me a late model Hemi bracket engine [Re: MattW] #1057460
08/21/12 10:17 PM
08/21/12 10:17 PM
MN
hemidup Offline
hemidup  Offline
MN
From other G3 Hemi engine builders I've talked to, their theory of oiling issues is due to the factory crossed drilled crankshaft. Kinda like running a rear U joint in a drag car thats equiped with a grease zerk.
Also, if you can maintain the same amount of oil pressure lb for lb at rpm using a 5.7 oil pump vs a 6.1 that's rated at a higher volume, why do you want that much oil in the heads when it can't drain back to the pan fast enough? We'll have to go back in time to 1967 when Chysler went from the 5 qt oil pan to a 6 qt cause guy's were sucking the pan dry at sustained rpm. Can't change the factory oil pan today in Stock eliminator. However, there is a faster way to return the oil.
Jerry Williams.
Re: Design me a late model Hemi bracket engine [Re: B3422W5] #1057461
08/22/12 01:59 PM
08/22/12 01:59 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
That's AJ's car, and it's only going to get faster.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Design me a late model Hemi bracket engine [Re: AlexP] #1057462
09/16/12 02:22 AM
09/16/12 02:22 AM
Toronto
mshred Online content
mshred  Online Content
Toronto
Thought I would get this thread back to the top since I am seriously considering getting rid of my LA stuff and going 5.7 in my scamp. I have tried searching for the answer to this question high and low here, but haven't found much so thought I would ask
I am wondering about stock bottom ends and what they can handle. Looking at a 2008 core motor that currently has a spun rod bearing. I have heard that high ten's in a 3400lb car are easily achievable with these engines potential, and im wondering if that can be done with a stock bottom end (I know the pistons are cast, rods powdered, and the crank is cast- although cranks are said to be decent in strength) and with the early 5.7 heads? Or would something of this caliber require upgraded bottom end parts (i.e. 6.1 crank, rods?, pistons?) and something like 6.1 or 5.7 Eagle heads?
Any insight on this stuff would be great, and I have to say, I read this whole thread for about the third time and it has a TON of great info, so thanks to all who shared so far
Thanks!
Re: Design me a late model Hemi bracket engine [Re: mshred] #1057463
12/01/12 06:15 PM
12/01/12 06:15 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: Design me a late model Hemi bracket engine [Re: MattW] #1057464
11/23/14 12:51 AM
11/23/14 12:51 AM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
Re: Design me a late model Hemi bracket engine [Re: mshred] #1057465
11/26/14 05:59 PM
11/26/14 05:59 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Thanks!
I'm thinking about starting a thread walking through performance mods to a basically stock 5.7 and working the build all the way through to a forced induction engine. We just purchased and altered 23T and rather than going straight to a built turbo engine we might try a 5.7 out of the junkyard and work it through some performance mods and document the gains or losses on our dyno. If you would like to see some test just let me know and if it fits the budget (and parts laying around the shop) we may give it a go.
Most folks won't be running an altered but the HP/TQ info should be helpful.
Thoughts?
Re: Design me a late model Hemi bracket engine [Re: 1badx] #1057466
11/26/14 06:07 PM
11/26/14 06:07 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
DO IT! I want to do a 5.7 for my 67 Coronet and want to go turbo on a JY 5.7 to start. I would build the turbo system capable of feeding a properly built (forged) 5.7 but would start with a stock one
Re: Design me a late model Hemi bracket engine [Re: WO23Coronet] #1057467
11/26/14 06:32 PM
11/26/14 06:32 PM
Canada
onig Offline
onig  Offline
Canada
YES, do it!
69 Dart
Re: Design me a late model Hemi bracket engine [Re: 1badx] #1057468
11/26/14 06:41 PM
11/26/14 06:41 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Thanks!
Thoughts?
sounds awesome
