Re: Design me a late model Hemi bracket engine
[Re: mshred]
#1057449
03/29/12 11:46 PM
03/29/12 11:46 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
talked to kent this mourning he said anyone interested in the intake can call him @585-610-9979 his cell or mike wear @ muscel motors for any info or to order one, later guys
there a price on this thing yet for the public?
Also, I would be hours looking through this whole thread again, but I could swear someone had the part number for a complete longblock (or shortblock?) 5.7 or 6.1 (or both) from the dealer. Is this still so? are they available? or would someone need a VIN to get one?
Sorry forgot to put this in P5155437.
[Re: CHAPPER]
#1057453
08/09/12 08:21 PM
08/09/12 08:21 PM
MattW
Ontario Canada
Nope I'm building my R3 4.25 stroke Indy 230 CNC head engines. I have my head in the sand. But since I have everything to put my R3 together it was a no brainer. Still working on the G3 but gathering info. Like to know if the oiling issue is fact or fiction? There is rumor of a 6.2 litre G3 supercharge engine coming out. Would like to get the block specs on that one. Me THINKS they would drop the bore to increase the wall strength. Matt
[Re: 540challenger]
#1057455
08/10/12 02:22 PM
08/10/12 02:22 PM
MattW
Ontario Canada
Well after changing my build to include the MP alum. block i tapped out the funds. Also since looking at the power level i might be pushing i decided to do the rest of the metal work on my challenger an cage so i don't twist that car. Then i have to wait for Matt to get his build done first, So i can make sure i run .001 faster then him.
If u wait for me ill be in a pine box. I was already to go full bore on my car since the wife ok'd it. Now I maybe going on strike at the end of the year. I really don't think we are going. It will depend on what the teachers do Aug 28. They will set the tone for the rest of Ontario government. If we dont go out, this time next year I'm hoping to be driving my paper weight. If you really want to be faster than me borrow your kids tricycle.
[Re: MattW]
#1057456
08/10/12 02:46 PM
08/10/12 02:46 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I am considering building a 3G for a Duster and would need to run 9.50s all out, and the car would be used to race in super gas, and other index racing. i just want make sure these will work and last. what size motor would work and what heads,comp....
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#1057458
08/20/12 05:09 PM
08/20/12 05:09 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
I talked to Arrington a while back They offered a 426 inch motor with a 267/271 hydralic roller, drag pack intake, at about 12 to 1 compression complete that they said would make an honest 650 ponies. A motor nearly identical to this is installed( shop car they have on website) in a new body style charger that i believe has gone 10.20s ish at around 4000 pounds, but i think has a bit less compression( dont quote me on that) Based on that, i suspect a 3000 pound A body should runs mid 9's carburated without a lot of trouble once sorted out. Motor complete was 13 grand ish as i recall.This included an optional setup that mounted coil packs on the intake.
Basically an assembled longblock with intake and coil packs, and using they're trick rocker gear, and fully ported heads they supply, custom crank rods and pistons.
[Re: B3422W5]
#1057459
08/20/12 09:28 PM
08/20/12 09:28 PM
MattW
Ontario Canada
Its all in the heads. they flow so much with so little effort. You have Eddies coming out with a victor aluminum head don't know what date. You have INDY with all their customer service and quality products and even with all this you will need serious effort RE $$$$$$$$$$ to get the flow numbers any where near the ported G3 head I will be building one in the future but for now since I have all the parts my R3 is going together. Once completed and my car is running, the G3 starts. Still trying to figure out what the oiling issue is, if there is any For now Its R3 time.
[Re: MattW]
#1057460
08/21/12 10:17 PM
08/21/12 10:17 PM
Posts: 833 MN
hemidup
MN
From other G3 Hemi engine builders I've talked to, their theory of oiling issues is due to the factory crossed drilled crankshaft. Kinda like running a rear U joint in a drag car thats equiped with a grease zerk.
Also, if you can maintain the same amount of oil pressure lb for lb at rpm using a 5.7 oil pump vs a 6.1 that's rated at a higher volume, why do you want that much oil in the heads when it can't drain back to the pan fast enough? We'll have to go back in time to 1967 when Chysler went from the 5 qt oil pan to a 6 qt cause guy's were sucking the pan dry at sustained rpm. Can't change the factory oil pan today in Stock eliminator. However, there is a faster way to return the oil.
Jerry Williams.
[Re: B3422W5]
#1057461
08/22/12 01:59 PM
08/22/12 01:59 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
That's AJ's car, and it's only going to get faster.
[Re: AlexP]
#1057462
09/16/12 02:22 AM
09/16/12 02:22 AM
Posts: 3,428 Toronto
mshred
Toronto
Thought I would get this thread back to the top since I am seriously considering getting rid of my LA stuff and going 5.7 in my scamp. I have tried searching for the answer to this question high and low here, but haven't found much so thought I would ask I am wondering about stock bottom ends and what they can handle. Looking at a 2008 core motor that currently has a spun rod bearing. I have heard that high ten's in a 3400lb car are easily achievable with these engines potential, and im wondering if that can be done with a stock bottom end (I know the pistons are cast, rods powdered, and the crank is cast- although cranks are said to be decent in strength) and with the early 5.7 heads? Or would something of this caliber require upgraded bottom end parts (i.e. 6.1 crank, rods?, pistons?) and something like 6.1 or 5.7 Eagle heads? Any insight on this stuff would be great, and I have to say, I read this whole thread for about the third time and it has a TON of great info, so thanks to all who shared so far Thanks!
[Re: mshred]
#1057465
11/26/14 05:59 PM
11/26/14 05:59 PM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
Thanks!
I'm thinking about starting a thread walking through performance mods to a basically stock 5.7 and working the build all the way through to a forced induction engine. We just purchased and altered 23T and rather than going straight to a built turbo engine we might try a 5.7 out of the junkyard and work it through some performance mods and document the gains or losses on our dyno. If you would like to see some test just let me know and if it fits the budget (and parts laying around the shop) we may give it a go. Most folks won't be running an altered but the HP/TQ info should be helpful.
Thoughts?
[Re: 1badx]
#1057468
11/26/14 06:41 PM
11/26/14 06:41 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Thanks!
Thoughts?
sounds awesome
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
