Page 23 of 31 1 2 21 22 23 24 25 30 31
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057349
12/16/11 08:11 PM
12/16/11 08:11 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Just putting this back up where I can find it quicker.... Did get some parts for my build today,,maybe make some headway in a few days.
If you like drag racing, support your local track.
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057350
12/19/11 11:22 AM
12/19/11 11:22 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Well I just got back from my local dodge dealer. No sign yet for a 6.4L complete or long block yet. Nothing for just the block but he did find a short block for $2800 however showing none instock anywhere yet
not mine, just found it
http://www.ebay.com/itm/2012-Dodge-Hemi-...ies&vxp=mtr
Wow that is a great price! But what the hell is wrong with Mopar a 500.00 core charge on a brand new engine. First the eagle head gets a core charge now this BS. I can understand the 6.1L stuff having a core but not the still in production stuff. First locking up the PCM's, Now core charges on brand new parts. Mother Mopar is sure making this hard to get into.
Sorry for the rant
I share your grief.
IMO something is not right. Why would you get a clutch with the engine if it is a crate engine?
Why doesn't he state the Part # ?
On a different note what is the best PCM to program?
I am hearing that the 2004 truck computer is the best one.
If it is , why?
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057351
12/19/11 12:44 PM
12/19/11 12:44 PM
NY usa
540challenger Offline
NY usa
Sorry for the rant
I share your grief.
If it is , why?
I spoke to Don with Arlington engines "spelling" According to him the tuner he is using runs the truck pcm he said 2006-2007 he sells the computer and the wiring for $2500.00 I would assume the older pcm would work also because of less security so the tuner can program it but it might be a different wiring harness to use. Arlington's harness is supposed to be a plug in for our muscle cars but I am not at that point yet to pull the trigger.
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057352
12/19/11 02:14 PM
12/19/11 02:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I think the 2004 is for the engine not having MDS
It will be nice if Mopar releases the 392 like the did for the 6.1 for around 6000.00. I would definately purchase one for that price.
470 hp 470 tq with all the smog stuff on
Set of headers lock out the cam and a program. I think 500 hp is easily obtained.
Hell I would even concider the 2009 to present 5.7 it has 400 hp.
I saw your post on the LX forum about the 392 hemi Part #.
I believe the guy's name was modern muscle that has 392 production hemis for sale.
I would to know why they are not giving out a part # and why are they replacing the intake manifold with the 6.1 aluminum one.
Actually I know why, it is because its an active intake design. It uses duell runner lenghts that at low rpm 4800 and below the engine runs on shorter plenum runners. At 4800 there is a switch that open and it goes to the larger runners. They have no way of using this feature with the older computer. Should be a simple solution with an auxilary switch
But the big issue that would leap MOPAR INTO THE 21 CENTURY IS RELEASE THE COMPUTER CODES.
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057353
12/19/11 03:06 PM
12/19/11 03:06 PM
NY usa
NY usa
My guess he is not giving out the part# b/c he is the only game in town with the production engines or at lteast 3 of them. He must know someone on the inside to get that many. You can use the later pcm that has the MDS in them a tuner should be able to delete that funtion.
As for the 6.4L intake there was a post a while back on the lx forums. That runner's don't just switch postion from short to long long. They slwoly open according to rpms and the problem is, it depends on feedback from the transmission too.
The way i am going to go IF everything works out is.
6.4L long block manual trans version so no mds.
upgrade to cam COMP has a few coming out,
Lock out the VVT comp cams again.
Get the 07 5.7L yunkyard motor truck version. Use TIN and drive accs.
Make sure on the senors are the same or can be swap over to the 6.4L.
The is a guy on the lx forum making an new intake for the 6.1L that flow more then aposted 6.1 intake and takes all the 6.1 parts for $650.00
get the computer and harness from Arlington great guy to talk to on the phone by the way.
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057354
12/19/11 08:21 PM
12/19/11 08:21 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
So the intake works like that There was a video on youtube that showed a chrysler engineer talking about the active intake. Thats were I got the 4800 rpm thing.
I wonder if a spring would work like how you would adjust the secondaries on a Thermobog.
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057355
12/19/11 08:30 PM
12/19/11 08:30 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
.."Modern Muscle..." who, where, what, etc. Just wondering about this Modern Muscle name...???...saw a camshaft with that name on the box..??
Re: Design me a 3G Hemi bracket engine [Re: CHAPPER] #1057356
12/19/11 10:40 PM
12/19/11 10:40 PM
NY usa
NY usa
Modern muscle is big on the 3rd Gen Hemi stuff from conversion to LX upgrades. He actually came out who the vvt cam phaser before comp cams did.
He also used to work for Arlington engines"shop hemi" Don from there said they are local to each other and Dave Weber was a very smart guy thats says alot when you competition says that about you.
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057357
12/20/11 12:30 PM
12/20/11 12:30 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Is it the same Dave Weber who help Mopar design the R3 and also came out with a small block belt drive?
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057358
12/20/11 01:47 PM
12/20/11 01:47 PM
NY usa
NY usa
No clue but IF it is the same guy it would explain how get got his hands on so many 6.4L production engines. hmmmmm
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057359
12/20/11 06:17 PM
12/20/11 06:17 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
yes its the same Dave Weber
and also the same Dave Weber from way back with the MOPAR Team of Ritter and Weber.
and another side note Dave is behind all of Mancinis Gen 3 HEMI stuff.
He has connections no doubt
Re: Design me a 3G Hemi bracket engine [Re: 340RICK] #1057360
12/20/11 08:54 PM
12/20/11 08:54 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
And here I thought that Modern Muscle was a fly by night operation.
This is a definite plus in my book that guy know his $hit.
Now I'm sure he has crate 392's for sale.
Rick hows your build coming? whos putting it together for you?
It is getting dry aroung here.
Re: Design me a 3G Hemi bracket engine [Re: 340RICK] #1057361
12/21/11 03:53 PM
12/21/11 03:53 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Here's some comments on the previous posts:
- Dave Weber at Modern Muscle is great to deal with and is involved in the Gen III Hemi swap scene. He does sell complete swap harnesses and ECU's.
- It's Arrington (not Arlington)and Dave did work there for a time.
- Also, you want to look for the 05 truck PCM. The 04 will work but the 05 is preferred. If you locate one and need a VIN# to flash to it email me and I will give you one (for the 05's only).
- If you can't find an 05 PCM I just set Dave up with 4 more so give him a call.
- You can disable MDS with the CMR software. If you need to have this done on a GenIII shoot me an email with your original backup and current tune file.
Re: Design me a 3G Hemi bracket engine [Re: 1badx] #1057362
12/21/11 05:22 PM
12/21/11 05:22 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
So without reading thru all the posts, where's a guy get a quote for a good old stroked bracket motor, or all the parts to build one starting with a good forged rotating kit...No stock rods or pistons. Who's listing these or a link?
Re: Design me a 3G Hemi bracket engine [Re: Dragula] #1057363
12/21/11 09:45 PM
12/21/11 09:45 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Call Stanton Racing in Nicholasville, Ky. I don't have the ph# right here...will post in the AM.
Re: Design me a 3G Hemi bracket engine [Re: CHAPPER] #1057364
12/21/11 10:13 PM
12/21/11 10:13 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Does anyone sell the 4150 to stock throttle body elbow for these engines? I know XV sells a longer version. Looking for a 90 elbow though.
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Design me a 3G Hemi bracket engine [Re: wldtm] #1057365
12/21/11 10:37 PM
12/21/11 10:37 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
my 6.1/426 is all done i fired it up with a carb. just to break it in. I have the FAST efi installed now and hope to be hitting chassis dyno after the holidays.
Re: Design me a 3G Hemi bracket engine [Re: 340RICK] #1057366
12/21/11 11:10 PM
12/21/11 11:10 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
The wiring harness is by far from done. I had quite a few snags with the EFI. Turned out to be a a problem with the harness. So anyway once I get it all tunned and running good I am going to tidy up all the wiring a make it look purty.
Re: Design me a 3G Hemi bracket engine [Re: 340RICK] #1057367
12/21/11 11:11 PM
12/21/11 11:11 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
one more
Re: Design me a 3G Hemi bracket engine [Re: 340RICK] #1057368
12/21/11 11:16 PM
12/21/11 11:16 PM
BPE Offline
BPE  Offline
Rick,
I can't wait to see it run.....if my "Dad" will take me to the track.
Rod
