Page 21 of 31 1 2 19 20 21 22 23 30 31
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057309
12/07/11 03:00 PM
12/07/11 03:00 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
The Hemi 6 Controller works excellent!! It basically uses the same software as the Digital 7 programmable via laptop.
I've run best of 11.05 @ 122mph at 3400lbs. Motor was a stock shortblock, ported heads, PWR cam. I hurt the stock short & blew it up at Monster Mopar, so I have a new motor in the works.
Congrats and sorry to hear you hurt the short block
What were you reving to and which engine 5.7 or 6.1?
Re: Design me a 3G Hemi bracket engine [Re: 1badx] #1057310
12/07/11 03:11 PM
12/07/11 03:11 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
6.1 motor...had about 10,000 miles on it when purchased. I left the short alone, ported the heads, PWR 224/228 cam, DP intake, carb. Made peak power, 557HP at 6400, shifted at 6800-7000. Motor melted down at about 6200 rpm, after shift to 3rd gear.
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057311
12/07/11 03:17 PM
12/07/11 03:17 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Nice! On the LX/LC platforms and factory trans controller(TCM) we have to shift the cars before 6850 or they go into "Limp Mode". With some of the more rowdy PWR cams we are making power right up to 6900 but unfortunately can't use it.....
Forge the short, maybe a little more compression and cam and you will easily be running 10's.
Re: Design me a 3G Hemi bracket engine [Re: 1badx] #1057312
12/07/11 03:30 PM
12/07/11 03:30 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
just saying
Re: Design me a late model Hemi bracket engine [Re: 1badx] #1057313
12/07/11 03:33 PM
12/07/11 03:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I never said to use the DP intake, they are NUTS what they want for one. This intake is what I am talking about
http://www.summitracing.com/parts/EDL-7528/
two of thease carbs
http://www.summitracing.com/parts/EDL-1404/
$280
$280
$375
$185
$474
$1594 For all new stuff and you can use the cheap no intake engine.
Or you can go mod man intake for $400 and buy your fancy $400 carb and be even cheaper still.
Going that route,
$400
$400
$474
$185
$1459
If you are just trying to go bare bones you can get an eddy carb around $300 and save another $100
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057314
12/07/11 03:45 PM
12/07/11 03:45 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
just saying
Now that is pretty!!!
Is that an Indy intake?
Re: Design me a 3G Hemi bracket engine [Re: 1badx] #1057315
12/07/11 04:33 PM
12/07/11 04:33 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
just saying
hot heads 392 intake adapted by twaters
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057316
12/07/11 04:45 PM
12/07/11 04:45 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
just saying
Nicely done!
I hope you water pump setup works out. Please report back when it's up and running.
Re: Design me a 3G Hemi bracket engine [Re: 1badx] #1057317
12/07/11 05:40 PM
12/07/11 05:40 PM
STEFF Offline
STEFF  Offline
That's the plan! I'm using a 6.4 Block for this new motor, so it should be fun......4.100 bore x 3.795 stroke or maybe even 4.05 stroke. So, more cubes, little more compression & alot more cam!
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057318
12/07/11 09:44 PM
12/07/11 09:44 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nice work
Almost in the ten's with a stock 6.1 Hemi.
Try that with a 340 or 360.
I wonder if you would of got the tens with the factory intake and Computer.
You said your running a 6.4 block for your next build. Is this the new factory SRT8 block with the bigger camshaft? Thanks for posting
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057319
12/07/11 10:33 PM
12/07/11 10:33 PM
STEFF Offline
STEFF  Offline
Nice work
I do know what would've got me into the 10's with my previous motor.
My existing headers were too big for 370" which cost me torque which in turn affected my converter stall. Car was a pooch out of the hole as the converter was hitting at 4500, when it should've been hitting at 5300-5400. 1.60 60's with a ladder bar & no tire spin. I dyno'd my motor with 1 3/4" dyno headers. Early on before the dyno, I built a set of 2" primary headers & they were way too big for the motor. I'll bet it cost me easily 30-40 ft. lbs. Live n Learn!! Bigger is no always better!
Had the torque not been down, it would've been there in the 10's no doubt.
Yes, I have the new SRT8 6.4 block.
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057320
12/08/11 07:22 AM
12/08/11 07:22 AM
NY usa
540challenger Offline
NY usa
If you don't mind how much did the 6.4L block cost? I went to my local dodge dealer a few months ago and no pricing yet...
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057321
12/08/11 11:01 AM
12/08/11 11:01 AM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
540Challenger - Is there a specific reason why you are considering a 6.4 block? I have not had any of the 6.4's in the shop but was wondering the benefits over a 5.7 which seem relatively easy to locate for cheap? Nothing against the 6.4. From what I've read it's the same bore as the 6.1 with the crank having a longer stroke. I also read that there are oiling passage mods but I'm not sure if they are for the MDS or overall improved oiling.
I just wanted to know if there are any specific advantages I am not aware of.
Thanks in advance!
Re: Design me a 3G Hemi bracket engine [Re: 1badx] #1057322
12/08/11 01:22 PM
12/08/11 01:22 PM
Clinton Twp. MI.
ChargerDude70 Offline
super street
super street
Clinton Twp. MI.
But calculate the cost... If you buy a 6.1 swap including the PCM, wire it yourself (not really that complicated, just time consuming) or purchase one of the $750 kits you can buy a used Predator tuning device for $200 and either attempt to tune it yourself or pay me $375. Now you have a grand total of $1500 (or $600 if you wire it yourself) invested in a killer, factory designed system.
1badx
I don’t post here too much anymore as my interest have changed. But occasionally something is brought to my attention. That said, I have 2 cars that I converted over to factory EFI 6.1L's. Ones a 4spd the other an auto. Your comment above caught my interest. If I am reading right, you are saying someone can take a LX series PCM(I used 2004DR PCM's)and use it for the conversion? If so, what are you doing about the SKIM(if activated)or the other inputs that PCM is requesting? Also,what year is most compatible? I have(3)2007 LX 6.1L PCM's in my possession.
Also, what is this $750.00 kit you are referring to? Can you be more specific?
DODGE...Devistation On Driving Grounds Everywhere 69 Dart Swinger 6.1 Hemi 4-Spd 70 Charger R/T B3/B5 6.1 Hemi Auto 76 Coronet 2008 H.D. Street Glide Aniversary Model 821 of 3000 2011 Challenger R/T T.O. 6spd
Re: Design me a 3G Hemi bracket engine [Re: ChargerDude70] #1057323
12/08/11 07:07 PM
12/08/11 07:07 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
1badx
First off, being selfish, how much do you want for the LX pcms?
Second, my only experience with the swaps has been with 5.7 truck engines (a local truck salvage company calls me when they get these in).
They have all been 04/05 model years. And there have not been any SKIM/VATS issues to deal with.
I called to verify my cost on harnesses and waiting on a callback. However, there seems to be quite a few out there but the retail is $950
I will try to get the specifics if other year units will work and if so what is required (from the same company I buy my harnesses from).
I am also updating my previous post (if I can) recommending that pre-2009 PCM's should be used.
From a CMR tuning perspective the pre-2009 has active VE tables but if the SKIM or other CAN bus issues are involved then the only option I can validate may be the 2005 5.7 truck PCM.
Good call out and I apologize for being misleading if in fact the other model year PCM's will not work.
Re: Design me a 3G Hemi bracket engine [Re: 1badx] #1057324
12/08/11 10:53 PM
12/08/11 10:53 PM
NY usa
NY usa
Thanks in advance!
If my research is right the 6.4L bore is 4.09 while the 6.1 is 4.055. Anyway i think it is the must bang for the buck unless i get a killer deal on something else.
My reason.
1. starting at 470/470 factory should be more then enough to push my challenger into the 11's with a stock engine.
2. cost. IF and that is a big IF the 6.4 is priced at around the same price as the 6.1. 7500.00 from mopar complete with wiring harness and all the senors. IT would be a killer deal.
3. A huge cost with the 3rd gen Hemi's is the core charge most engine builders have running as high 1500-2000. Which i can understand giving the block head wiring and senors cost.
4. With a cam swap, headers and a tune i should have well over 525 ponies on tap.
Granted this all depends on the price of the 6.4L IF it is around the 6.1L pricing.
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057325
12/09/11 12:08 PM
12/09/11 12:08 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Question on the building of these engines,,,what kind of results are people seeing, re-using the original gaskets? I am referring to the water pump, valve cover, spark plug tube to valve cover, timing cover, etc...the o-ring style gaskets. Rumor has it, that they are designed to be re-used. I thought if in good shape, they would probably be OK,with possibly some sealer. What have others found out?? THX
If you like drag racing, support your local track.
Re: Design me a 3G Hemi bracket engine [Re: CHAPPER] #1057326
12/09/11 12:31 PM
12/09/11 12:31 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
I personally clean and reuse the o-ring seals unless they are damaged. No sealant unless the surface is rough. Customer cars get new o-rings.
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057327
12/09/11 09:08 PM
12/09/11 09:08 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
My reason.
I'm missing something. When did Chrysler or any other compagny start offering cams for the VVT engines.
How do you manage to tune the production 6.4 engine with the production computer?
Don't take this the wrong way, I hope that someone somewhere has manage to crack the roaming encryption codes that Chrysler is now using. I heard that they are almost impossible to crack
Keep us informed.
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057328
12/10/11 09:41 AM
12/10/11 09:41 AM
NY usa
NY usa
My reason.
Keep us informed.
I think there is one compnay making cams for the VCT motors I thought remember the name it was on the LX forums but You can always send out the factory came to be reground.
As of now you can't tune the motors but that will changes heck it the same thing was said about the 3rd Gen Hemi when they first came out.
I plan on useing an older PCM to so you can tune it.
The VCT is easy to get around b/c there is 2 companies out there that make a part that locks the VCT in place so you can use an older computer. Modern muscle and Comp Cams both have one.
