Hey all,
I am in the process of teardown and I have the 8 3/4 out of the car.
I wanted to clean it up and paint it, so I decided to dissassemble. Did I need to? Not really, it was working fine. But curiousity got the best of me...lol.
Anyways, all I did was pull the pig and shafts, so what exactly am I looking for in regards to a potential problem? I mean how do I perform a proper inspection?
I can provide some pics if it can help.
Plus, Ive always heard that if you pull the axles, you should automatically replace the seals. Is that true? Didnt guys back in the day, change out the center section at the track, (going from street friendly gears to race)therefore pulling the axles? I cant imagine guys changed the seals when they did that.
If everything checks out fine, do I just assemble it the same way I took it out or do I need to make some adjustments (end play, etc).
Sorry for newb questions, but I have never really looked into rear end stuff. Now that I have it apart, it looks pretty straitforward, but I figured I would ask you guys to be sure Im going about it right.
Thanks and any help is appreciated.
Ill post some pics in a little while....
Oh yeah, almost forgot, 80-90 okay? about 2+ quarts or until it starts to seep out the hole? Its SG, so how bout additive?
