Ballast and coil question #1056503
08/19/11 01:31 AM
08/19/11 01:31 AM
CA
mojavered Offline OP
CA
If you look up the MSD Blaster 2 coils, they say that they are for points set ups only. It also says that you need a ballast only if you are running points.
I am running a mopar electronic distributor with vacuum advance with the MSD high vibration coil. Do I need a ballast with this setup? I have the .8 ohm ballast that MSD recommends for the coil. Running the chrome box. Thanks.
71 Challenger RT
440 / 727 / 8.75
Re: Ballast and coil question [Re: mojavered] #1056504
08/19/11 03:07 AM
08/19/11 03:07 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
With the Blaster II & chrome box you should be running a 0.25 Ohm ballast resistor.. Mopar part #P2444641.
Just my $0.02...
