holley carb question....corroding metering block
#1056387
08/18/11 08:32 PM
08/18/11 08:32 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
hello all. i have a question about a holley 4160 i have on my boat. here goes. it's a 600 cfm 4160 and i had it reworked/modified by a holley specialist in litchfield ohio. we did all kinds of cool stuff like milling off the choke horn and blueprinting it/specifically setting it up for a marine application. the boat seemed to be down on power lately as if it was starving for fuel so i started at the tank and worked my way to the carb thinking i had possible obstruction in the system. when i got the carb on the bench and removed the front float bowl i found that the metering block was literally corroding apart. cracks all over it and a grimy/gritty type gunk (not a lot of gunk but there none the less). i'm thinking it's this crap pump fuel with the ethanol in it that is corroding it. has anyone else had anything like this occur? the carb guy i use builds high dollar pro stock and off shore marine holley stuff so i have all the faith in the world in what he did for me. i'm sure the corrosion happened after he worked on it and has nothing to do with his work. i intend to phone him in the morning but i thought i'd see if anyone here has had similar problems. i just want to figure this out so i can put it to bed once and for all. i may have to start my season out every year with a 55 gallon drum of known quality gasoline. thoughts anyone?
unions....the folks who brought you the weekend!
Re: holley carb question....corroding metering block
[Re: mikemee1331]
#1056389
08/19/11 07:32 AM
08/19/11 07:32 AM
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
the gaskets are fine. i pulled the tank and it is absent of debris.
i was doing a google search last night and i'm fairly certain it's the ethanol blend that's the culprit. we have it in ohio. seems i'm not the only one that has had this problem with an engine that sits between usage.
anyone else?
[Re: Challenger 1]
#1056391
08/19/11 09:44 AM
08/19/11 09:44 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
If its white like substance its moisture, if its bad enough you'll play hell cleaning it up, if its flaking chunks then like mentioned the protected surface is gone, either way your best bet is finding another MB & be done, check the rest of the carb closely for the same issues, you may just need to get another carb. Holley did have an issue with the plating coming off & the carb started chunking apart literally, i had this happen last year on a used 650dp that i purchased off e-bay believe it or not, Holley was very good to me & replaced the parts i sent them for a brand new one in the box.
[Re: dogdays]
#1056393
08/19/11 01:11 PM
08/19/11 01:11 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Hagertys insurance is doing a long term study of the effects of alcohol fuel on old cars and the preliminary results show no harm is caused.
I bet you got some water in the fuel.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
