Overheating: Bad fan clutch? Or tips on quick fix?
#1055442
08/18/11 11:27 AM
08/18/11 11:27 AM
Posts: 5,660 Flint, MI
Gusteve
I Love the Unicorn Song!!
Flint, MI
Greetings all,
My car has started overheating in traffic. With Woodward going going on this week it's taking all the fun out of it. It was fine last year, but I noticed earlier this year that the temp would creep up if I was idling.
Since it used to be OK, I'm thinking maybe my fan clutch is going bad. Is there any way to test this without just putting a new one on?
Or, might there be any other suggestions for a quick fix? I don't have a shroud (I know, I know, I just never got around to it because it used to be fine). Is it possible to cobble something together?
Thanks!
Re: Overheating: Bad fan clutch? Or tips on quick fix?
[Re: Gusteve]
#1055443
08/18/11 11:34 AM
08/18/11 11:34 AM
RapidRobert
W it OK last year the stat may have partly stuck from sitting (pull it & retry WO it & you'll know right away) but on the clutch fan, I think you try to spin it when hot & should have some tension
[Re: Gusteve]
#1055444
08/18/11 12:46 PM
08/18/11 12:46 PM
Posts: 19 Michigan
Superbee '69
I was having similar problems with my Super Bee and never considered it might be something so simple as a t-stat, it was. Now I have some other issues but thats in another post. Anyway, try the stat.
1969 Dodge Coronet Super Bee(clone)Go Green - 383HP, Edelbrock aluminum intake, Holley 750, Hedman headers, 3" Flowmasters, 727 Trans Go, 4:11s
