67 GTX hood scoop locations #1054770
08/17/11 01:37 PM
08/17/11 01:37 PM
Tucson, AZ
67G2THEX Offline OP
67G2THEX  Offline OP
Tucson, AZ
I've searched and searched the forums to no avail. I'm making a GTX clone out of my 67 Satellite, and I'd like to add the scoop holes to the hood before I move on with wrapping up the body work. Does anyone have some really good reference on locating the hood scoops correctly? I found this image of the scoops on a 70 B during my search, that basically shows what I'm looking for. All help is appreciated.
PS> Anyone know where to get studs/nuts for the scoops?
Thanks guys!
Carey
1967 GTX 440 Auto Tribute
1968 Charger 440 Auto
1968 D100 318 Auto Stepside - Daily Driver
1974 Road Runner 318 Auto
1954 Coronet 2dr Hemi Std with O/D
73 Road Runner 360/4spd Sassy Grass - sold
71 Challenger R/T Clone 383 MAG Auto - sold
Re: 67 GTX hood scoop locations [Re: 67G2THEX] #1054771
08/17/11 07:48 PM
08/17/11 07:48 PM
Tucson, AZ
67G2THEX Offline OP
67G2THEX  Offline OP
Tucson, AZ
anybody?
Re: 67 GTX hood scoop locations [Re: 67G2THEX] #1054772
12/21/11 08:05 PM
12/21/11 08:05 PM
MI.
mech440 Offline
mech440  Offline
MI.
Was anybody able to answer this? I an looking for same info....
adding scoop to a hood that did not come with scoops originally
and there are no predrilled holes. Thanks all!!!
If it doesn't have a motor.....it's not a REAL sport
Re: 67 GTX hood scoop locations [Re: mech440] #1054773
12/21/11 10:55 PM
12/21/11 10:55 PM
IOWA
DOMINATOR5D Offline
DOMINATOR5D  Offline
IOWA
I just measured mine Front of left scoop at bezel is 2 1/2" from the edge of the hood and 16 1/2" to center of hood on other side of scoop at bezel Back edge of scoop is 3 5/8" from back edge of hood measured at the center of the scoop. The rear of the scoop just before curve is 3 1/8" from the side edge of the hood and 17 1/2" to center of hood on the other side of the scoop. the other side of hood is the same. 6 of the 8 mount bolts go though the sub structure of the hood so the holes in the structure have to be bigger [for the nuts and socket to tighten them] than the holes in the hood panel its self. Good luck Bob
Re: 67 GTX hood scoop locations [Re: DOMINATOR5D] #1054774
12/22/11 01:28 AM
12/22/11 01:28 AM
Colorado
67plymouthman Offline
Colorado
PM me your email address and when I get home I will take some pictures of my GTX hood that I took the scoops off of. The hood is for sale.
Re: 67 GTX hood scoop locations [Re: 67plymouthman] #1054775
01/01/12 08:34 PM
01/01/12 08:34 PM
MI.
mech440 Offline
mech440  Offline
MI.
Thanx for the replies.
I appreciate the help guys... will post some pics soon.
Re: 67 GTX hood scoop locations [Re: mech440] #1054776
01/02/12 03:40 AM
01/02/12 03:40 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Heres some pics, I hope they help.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 67 GTX hood scoop locations [Re: Hemi_Joel] #1054777
01/02/12 03:41 AM
01/02/12 03:41 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
2
Re: 67 GTX hood scoop locations [Re: Hemi_Joel] #1054778
01/02/12 03:41 AM
01/02/12 03:41 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
3
Re: 67 GTX hood scoop locations [Re: Hemi_Joel] #1054779
01/02/12 03:42 AM
01/02/12 03:42 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Re: 67 GTX hood scoop locations [Re: 67G2THEX] #1054780
01/03/12 12:54 AM
01/03/12 12:54 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
Did you look at the underside of the hood? It's obvious where the scoops go.
Re: 67 GTX hood scoop locations [Re: sixpack4spd] #1054781
01/03/12 01:07 AM
01/03/12 01:07 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Only if the hood is a 1967. Not if it is a 66.
Re: 67 GTX hood scoop locations [Re: Hemi_Joel] #1054782
01/03/12 05:09 PM
01/03/12 05:09 PM
MI.
mech440 Offline
mech440  Offline
MI.
Great , perfect , exactly what I need!
Thanks, I know I can always count on you guys here.
Re: 67 GTX hood scoop locations [Re: mech440] #1054783
01/05/12 08:01 PM
01/05/12 08:01 PM
MI.
mech440 Offline
mech440  Offline
MI.
Ok holes are drilled, scoops fit , Thanks again guys!!
Now the next question is does anyone know where or if
anyone sells the mounting nuts??? I know thay're nut just standard nuts as they have to clear the shoulders where the studs are mounted.
And unfortunately I need them!!
You guys are the best!!!
