Where to buy a 26" 3 or 4 core rad? #1054090
08/16/11 03:34 PM
08/16/11 03:34 PM
MA
Mass_Mopar Offline OP
MA
I need a stock replacement 26" radiator for my New Yorker - I bought a 26" 4 core for my Charger but I forget where I got it from. I'm trying to get a reasonably priced radiator that's close enough to stock to re-use the shroud. Any suggestions?
Re: Where to buy a 26" 3 or 4 core rad? [Re: Mass_Mopar] #1054091
08/16/11 03:47 PM
08/16/11 03:47 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I took my stock 26" 2-core rad from my Challenger to a local rad repair shop. I asked for a 4-core. He said the rad wasn't big enough for a 4-core, but he could do a 3-core. I had him do that, and have been pleased with the results. Been using the rad for 7 years now with no problems, and of course the factory shroud fit perfectly....
Re: Where to buy a 26" 3 or 4 core rad? [Re: 318 Stroker] #1054092
08/16/11 04:05 PM
08/16/11 04:05 PM
Butler, PA
romanucci Offline
romanucci  Offline
Butler, PA
That's what I did. A local rad shop put a 4-core inside of a 26" C-body rad for $300 total.
Re: Where to buy a 26" 3 or 4 core rad? [Re: 318 Stroker] #1054093
08/16/11 04:07 PM
08/16/11 04:07 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Re: Where to buy a 26" 3 or 4 core rad? [Re: markz528] #1054094
08/16/11 06:53 PM
08/16/11 06:53 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
http://www.usradiator.com/
I can only speak to my recent purchase from US Radiator, only three of the mounting holes lined up, the top inlet tube is off by 2 iches, the bottom inlet is also off, the trans line are also off by 2 inches and on top of that it leaks on the bottom and when I told the guy who sold it, he said and I quote " I can't believe you can't streach the hoses two inches" and they will not take it back.....buy at your own risk
Semper Fi
Re: Where to buy a 26" 3 or 4 core rad? [Re: Mass_Mopar] #1054095
08/16/11 07:27 PM
08/16/11 07:27 PM
Arizona
az426john Offline
az426john  Offline
Arizona
I had a triple core put in my 67 GTX. It is 3/8" tubes on 3/8" centers. I think it was called an MX core by the manufacturer, but the important thing is the number of tubes and the spacing.
My Hemi car runs sufficiantly cool here in the Arizona desert with this radiator and a 4 blade fan with a solid spacer and a shroud even in the summer months.
Re: Where to buy a 26" 3 or 4 core rad? [Re: Mass_Mopar] #1054096
08/16/11 08:02 PM
08/16/11 08:02 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
Nick,
The radiator in the Polara was recored by a place in Medford or Somerville a couple of years ago. I can't remember where, though. It does fine in parades.
Steve
Someday I'll have another C-body.
