Re: Paint experts - Soft MX241 primer/filler concern.
[Re: 70mopes]
#1053856
08/16/11 08:49 AM
08/16/11 08:49 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
i have never used that primer so i can't give you exact comments about it. the primer is gray correct? with a 2K primer it will cure slower if you don't use proper flash times. i know with other PPG heavy solid primers similar to this stuff won't properly cure without using a heat lamp. my suggestion is to get the car in the sun to bake it. or get out a heat lamp to give it a full cure.
perception is 90% of reality
[Re: 70mopes]
#1053859
08/16/11 05:00 PM
08/16/11 05:00 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Yes, a light gray polyester primer.
sounds like you didn't mix the Omni properly?,....I usually use the Evercoat G2 polyester primer/fill, pot life is only 15-20 minutes, so if it don't set like rock within that time frame you know you did something wrong, mix wise,....or perhaps the mat'l was frozen at some time before you used it, if you can't cure the car in the sun, or a heat booth,....time to scrape it off,...IMHO avoid the OMNI line, I have little love for PPG products, Omni is rock bottom as far as quality though, much like the Nason brand line is junk for Dupont,....Evercoat is perhaps your better line for polyester resin primer/fill sprayable products,...sucks to have the situation your at, but better to remove it now, than after trying/hoping it will cure under the paint, which will just be a bigger mess down the road
Mike
[Re: elitecustombody]
#1053862
08/18/11 11:35 AM
08/18/11 11:35 AM
Posts: 1,228 Maple Valley, WA
70mopes
Maple Valley, WA
Thanks for the replies. The Omni is coming off and will be replaced with G2. Don't want to tempt fate with the crappy job I did the first time around. In hindsight there were multiple errors on my part that lead to the poor results. The product had sat for to long and became very viscous , I did not use enough hardener, the use of reducer may have affected cure and application without adhering to flash time requirements. With a wife and kids, I was attempting to get more done than I should have with the window of opportunity I had and tried doing so without taking the proper steps to make sure I did it right. Patience is a virtue they say... especially when it comes to the restoration process - every aspect of it. Thanks again.
