Lets hear your stupid fast small block combo's #1053484
08/15/11 06:08 PM
08/15/11 06:08 PM
Champion City
The Sphinx Offline OP
Champion City
We already did the fast 440's lets hear some small blocks builds using factory blocks. Lets not fight about big block vs. small block, they're all good in my book.
Re: Lets hear your stupid fast small block combo's [Re: The Sphinx] #1053485
08/15/11 10:15 PM
08/15/11 10:15 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
8.92 @ 149.95 mph 2850lbs no power adders well under 370 inches, R-3 block w-9 hand ported heads, more left in it, is that stupid fast enough???
Re: Lets hear your stupid fast small block combo's [Re: The Sphinx] #1053486
08/15/11 11:10 PM
08/15/11 11:10 PM
Guitar Jones Offline
Well mine ain't stupid fast but it is a stock block. Haven't had it to the track yet as I'm still waiting on the proper pushrods and thanks to Todd at Competion Wedge I'll be able to fix that soon enough. I expect mid 9's in the crappiest air out of this combo and I don't see a reason why it shouldn't do it.
Stock 360 block, tall filled with a Hughes girdle, torque plate honed and a 1/16 ring pack. W5 small chamber hand ported heads, 2.08/1.60 intake flows over 320 @ .700. 4" crank from BPE, Eagle H beams and Wiseco pistons with a 20cc dish including the valve reliefs. .006 out of the hole with .039 gasket. Crane SS solid roller with 1.6 rockers nets out to .698/.714 lift with the lash, 276/284 duration @.050.
I've done oiling mods that include drilling all the passages to .500 minimum and radiusing all the corners I could get to and blocking the oil to the lifters. A Melling HV pump with a Canton rear sump pan filled with 05W20 synthetic and a .625 ID pickup tube.It has an M1 W5 tunnel ram with 2 750 Demon TR carbs. Currently has Crane Gold rockers on it but thanks to Todd @ Competion Wedge it will soon have Harland Sharps on it. 2" primary header and a 4" collector with turn downs. 4200 TA converter and a low gear 904 with a 4.86 geared 8.75 rear at 2600 pounds with me in it. The combo in my sig is basically the same but with a .672 lift flat tappet with the same duration @ .050 as the roller but with 2.02 valves in the head and a basically stock short block with hyper pistons. Plus it's about 15 years old without a freshening so I don't think the new combo will have any problems getting well into the 9's. Results will be posted.
Re: Lets hear your stupid fast small block combo's [Re: Guitar Jones] #1053487
08/15/11 11:17 PM
08/15/11 11:17 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Stock block Steve.
I had a 378 which is a 360 bored .100" over. It ran 9.90's at 3400 lbs.
Re: Lets hear your stupid fast small block combo's [Re: Leon441] #1053488
08/15/11 11:23 PM
08/15/11 11:23 PM
Stock block Steve.
Well the OP said factory block. I suppose the R3 is a factory block, but considering there isn't much of anything else out there you could construe that to mean stock block.
Re: Lets hear your stupid fast small block combo's [Re: The Sphinx] #1053489
08/15/11 11:36 PM
08/15/11 11:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
8.96 @ 151...R-3 W-9 very mild 405ci 2405#
Re: Lets hear your stupid fast small block combo's [Re: MR_P_BODY] #1053490
08/16/11 02:13 AM
08/16/11 02:13 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
My definition of a factory block is one that was factory issue in a production vehicle....
My Indy headed 408 (factory '75 360 block) has been 10.11 @ 131mph. Regularly runs 10.20 to 10.30 in my 3000lb valiant. Oh yeah, it's only 10.3:1 compression also. By no means a stupid fast smallblock though... I'm making a few changes right now to hopefully squeeze a 9.9x pass out of it this fall.
W5Dart66 (Brett Miller) built a 397" Indy headed motor for Engine Masters a few years ago that made 660hp and went 9.70's @ 138 in a 72 Dart. Also, a pump (93 octane) gas motor.
Re: Lets hear your stupid fast small block combo's [Re: Leon441] #1053491
08/16/11 07:21 AM
08/16/11 07:21 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
Stock block Steve.
Sorry, I thought he ment any Mopar block. I went 9.502 @ 138 mph with a stock 1970 block out of my 340 swinger I used to own with w-5 heads and @ 3100 lbs. 372 inches and no power adders. It eventually slpit in half so i went with a R-3 race block. Is that stupid fast???
Re: Lets hear your stupid fast small block combo's [Re: stevet340] #1053492
08/16/11 07:44 AM
08/16/11 07:44 AM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
We've been 5.72 @ 119 with a stock block 340, 418 inches and W5s. 3220lbs with a 4.10 gear and street legal. This is with a .082 nitrous jet and 17 degrees of timing
82' dodge pickup with a 499 low deck
Re: Lets hear your stupid fast small block combo's [Re: JesseR] #1053493
08/16/11 08:25 AM
08/16/11 08:25 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have been 9.53 69 340 .055 over indy head 421 cu in with .073 jet at 3275lbs.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Lets hear your stupid fast small block combo's [Re: 1967dartgt] #1053494
08/16/11 09:56 AM
08/16/11 09:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Stock 340 block I went 9.54, home ported W-2s with
10.5 compression... happens to be in the car now
Re: Lets hear your stupid fast small block combo's [Re: MR_P_BODY] #1053495
08/16/11 01:35 PM
08/16/11 01:35 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Mine isnt stupid fast. But my 74 360 block W-5 headed 408 has been 5.93 @ 114.No Nitrous.My opinion of stupid fast w/ a SB would be close to the 8 sec 1/4s or 5.50s 1/8 stock or Mopar race block.
Re: Lets hear your stupid fast small block combo's [Re: DavidDean] #1053496
08/16/11 06:00 PM
08/16/11 06:00 PM
I think 5's in the 1/8th with no power adders is pretty stupid fast for a stock block. I hope mine holds up until I can get another R3. I had 2 and sold them, but I don't plan on leaning on this one real hard. Shouldn't have to to get what I want anyway.
Re: Lets hear your stupid fast small block combo's [Re: JesseR] #1053497
08/16/11 09:01 PM
08/16/11 09:01 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
That would not have happened to be at Rockingham in that mineshaft air last year? Would it?
Leon
Re: Lets hear your stupid fast small block combo's [Re: Leon441] #1053498
08/16/11 09:03 PM
08/16/11 09:03 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Stupid fast for a stock block is a relative statement. The weight of the car has to be considered.
Leon
Re: Lets hear your stupid fast small block combo's [Re: Leon441] #1053499
08/16/11 09:18 PM
08/16/11 09:18 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
A few years ago I was going 5.60's at 3500lbs on 408ci edelbrock heads.....
A few months ago went 128 mph in the 1/8th at about 50 more lbs..not a great et though..some bugs then.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Lets hear your stupid fast small block combo's [Re: instigator] #1053500
08/16/11 09:22 PM
08/16/11 09:22 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
That twin setup you got is stupid fast!
Leon
Re: Lets hear your stupid fast small block combo's [Re: Leon441] #1053501
08/16/11 09:47 PM
08/16/11 09:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Leon
Yep... I never had to make big power when running a
light car... that way I dont stress parts and break things
Re: Lets hear your stupid fast small block combo's [Re: Leon441] #1053502
08/16/11 09:49 PM
08/16/11 09:49 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Leon
i very much agree with that leon,he is stupid fast..on the other side dustermel i believe went 5.60 in a n/a sb..thats kinda stupid fast also..anything in the 5's is nice thats why as of right now,,im putting a speedtech plate on my junk..unless i find 10 g's somewhere
Re: Lets hear your stupid fast small block combo's [Re: Leon441] #1053503
08/16/11 10:12 PM
08/16/11 10:12 PM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
It would have been nice to have had more time down there to see how fast we both could have gone, thats the only bad thing about index racing, we spent all of our time trying to dial our cars in
