water pump? 6 blade or 8 blade? #105302
08/15/08 10:55 AM
08/15/08 10:55 AM
Anonymous OP
Anonymous OP
for a 416 with no AC.
whats the up/downsides of each.
I thought the 6 blade was for AC but I cant remember (I thought it was just the opposite of what you'd expect)
Re: water pump? 6 blade or 8 blade? #105303
08/15/08 11:09 AM
08/15/08 11:09 AM
Andrewh Offline
Andrewh  Offline
It is infact opposite of what you would expect.
8 blade is for non-a/c
6 blade is for a/c, but remember the pulley is smaller so it over drives the pump for an a/c car.
There really isn't a draw back, except if you use the non a/c pulley for an a/c pump, you may not get enough coolant flow.
Re: water pump? 6 blade or 8 blade? #105304
08/15/08 03:07 PM
08/15/08 03:07 PM
get an 8 blader & consider tacking on a flat disc to the impeller.
Re: water pump? 6 blade or 8 blade? [Re: RapidRobert] #105305
08/15/08 03:13 PM
08/15/08 03:13 PM
Anonymous OP
Anonymous OP
the engine cools very well right now. Not sure if I need any extra help in that department
Re: water pump? 6 blade or 8 blade? #105306
08/15/08 03:22 PM
08/15/08 03:22 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Like said above the 6 blade is for AC and 8 blade for non AC. The AC cars have a smaller water pump pulley to spin the fan faster. The 6 blade is used in this case to prevent capitation. If you car cools well now but you need a new pump I'd put back on whats on there.
