Super Stock Leaf Springs Installed: 2" higher on left?
#1052998
08/14/11 08:10 PM
08/14/11 08:10 PM
Posts: 53 Spring, TX
70cudaproject
Spring, TX
I finished installing new SS springs on my '68 Charger, and now it is 2" higher on the right and 4" higher on the left ![](/ubbthreads/images/graemlins/shock.gif) . I didn't expect the left to be higher. The right spring has more leaves and for some reason the left is higher. I have read this could be from bad quality control in Mexico. I installed them with stock shackles (currently vertical when on ground), 2" SS front hangers (used bottom hole), stock shackle mount, and no pinion angle shims installed yet. All bolts are currently loose to ensure no binding. The right (passengers) side spring part number ends in 454 and has 2 more short springs facing forward. The left one is stamped 45X but the MP sticker says 455. Did I get bad springs? Should I move the springs to the top hole on the hanger? Should I change to 1" longer shackles when I do this? Thanks Moparts Members!
Re: Super Stock Leaf Springs Installed: 2" higher on left?
[Re: 70cudaproject]
#1052999
08/14/11 08:48 PM
08/14/11 08:48 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
These were on my car when I bought it..What an old school nightmare... Good luck with your project.
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: screamindriver]
#1053002
08/14/11 10:11 PM
08/14/11 10:11 PM
Posts: 23 Orange County, Ca.
Revhendo
Orange County, Ca.
I put SS springs on the back of my Valiant 5 years ago. It's still a bit higher on the left. I can't tell you how many times I have been under the car checking the part numbers. Got it right the first time and I really don't have an answer for you. I am thinking of switching to the XHD springs or maybe even the Hotchkiss for my application.
Rev.
Isaac Asimov once said, "Individual science fiction stories may seem as trivial as ever to the blinded critics and philosophers of today, but the core of science fiction, its essence, has become crucial to our salvation, if we are to be saved at all."
[Re: 70cudaproject]
#1053005
08/15/11 11:03 AM
08/15/11 11:03 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Per Doctor Diff's advice, I simply used two left-side SS springs in my a-body with a 1 inch lowering block. Sits level, rides great, handles excellent and they haven't really settled in 4+ years. I added a rear swaybar and Koni's too.
Compared to some systems out there, it was a reasonably inexpensive upgrade over the tired stocker rear suspension.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 72N96RR]
#1053007
08/15/11 02:38 PM
08/15/11 02:38 PM
70cudaproject
Spring, TX
Those sure are some long shackles! Looks kind of like the Death Proof Charger...one of my buddies has a '69 with the same shackles - Mr.Gasket's I believe. First thing he did was adjust them to stock height and cut off the bottoms.
Monoleafs would of been nice. I just wanted something that would hook better and that I wouldn't get obsessed with adjusting - so SS filled the bill. Once I get the left side down a bit I will be happy. If the right was higher I would be happy because at least I understand how it helps traction. What I have should actually hurt traction. My '68 Charger has 4.10s, 3200 stall, .509 292 cam, solid motor mounts, and 10.5" tread in the back and 6" in front on ConvoPros. Since I am going for the '60s somewhat drag look I am actually like some rake, but prefer not to see the shackles. Thanks for the input. I think I will go stock R/T on my '70 AAR clone.
[Re: Dragula]
#1053008
08/15/11 02:48 PM
08/15/11 02:48 PM
jbc426
West Coast, USA
Per the pic above, that won't work on an E-body....Hits the valance. Not to mention super stock springs all suck. My car was horrible with them and I believe they are all chinese junk now a days. Go with Split Mono's and don't look back.
![](http://i427.photobucket.com/albums/pp357/cudahalr/6778479-shackleangle.jpg)
![](http://i427.photobucket.com/albums/pp357/cudahalr/70HemiCuda/Hemi97765.jpg)
Solution:
That's actually incorrect. A pair of same-side SS springs will work on an e-body with a stock rear valance using either the stock rear hangers or Dr Diff's 1" inset hanger kit I've had them on my e-body. I'm not 100% sure about the Mopar Performance inset hanger kit, but I believe that would fit too.
I didn't use the 1 inch LOWERING BLOCK on my e-body, but that doesn't affect the fit or the rear of the spring or hanger and would work too.
Longer rear shackles may hit the stock rear valence. I think that might be what you are referring to. I never commented on those however.
I'm sure not all SS springs are bad. Many sets continue to work well when used in the proper application. They work excellent in my a-body and have held up well over nearly five years with little or no sagging.
[Re: 70cudaproject]
#1053010
08/15/11 04:45 PM
08/15/11 04:45 PM
jbc426
West Coast, USA
There is something about the front spring segments being available in two lengths. One is shorter and must be used with a different front spring hanger, but I don't have the specifics at hand right now. One of the resident experts will likely update this info, or give Dr Diff (Cass) a call.
[Re: jbc426]
#1053012
08/15/11 09:59 PM
08/15/11 09:59 PM
70cudaproject
Spring, TX
That's right. I read in the Tech Archives that the front spring segments are 2" shorter than stock B/E body springs and therefore the 2" longer hangers must be used. I did install the SS hangers with the bottom most hole used.
[Re: 383man]
#1053013
08/15/11 10:02 PM
08/15/11 10:02 PM
70cudaproject
Spring, TX
Every set of SS springs I put on the cars sit uneven. I just adjust the front torsion bars to get it where I like and they all seem to work and hook fine. Ron
Good deal. I may just see how I like the stance with the 1" higher hole used on the hangers. Other than pinion angle do I need to change anything else when I use this hole? Do you personally use a rear end snubber? Thanks 383man.
[Re: 70cudaproject]
#1053014
08/15/11 10:13 PM
08/15/11 10:13 PM
They are essentially A-body springs with a 20" front segment although '63 only B-bodies used a 20" front segment as well. Later B/E use 22" front segment thus the need for longer hangers with SS springs.
