Seems that if I didn't have bad luck...
#1052424
08/14/11 12:37 AM
08/14/11 12:37 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
I wouldn't have any luck at all. So I took the car out finally today. First time since last Oct when I got a hole in the driver-side slick after one pass.
So today, I swap on the moroso blue valve cover gaskets to solve a nagging leak back by number 7. Not too bad, but causes embarressing smoke on first start up until it burns off. So while I had the valve covers off I check and tighten header bolts.
Get to the track, leak fixed. Hour plus in tech line. Finally make a pass and it spins bad, 1.63 sixty and then its popping in higher RPM's. Its never done that before, so I let off and coast to an 11.84 at 86mph.
Check it out back at the trailer and find a nice big crack in the number 7 header tube, right at the flange. Well, now I know where the popping was coming from.
Re: If I didn't have bad luck, I wouldn't have...
[Re: 8urvette]
#1052427
08/14/11 05:23 AM
08/14/11 05:23 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I had those gaskets and couldn't get on with them, i now use Greg's ( ROADHAZARD's ) superperformance gaskets much better and a reasonable price. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1052428
08/14/11 05:52 AM
08/14/11 05:52 AM
Posts: 660 San Diego
formula S
San Diego
![](/ubbthreads/images/graemlins/iagree.gif)
Re: Seems that if I didn't have bad luck...
[Re: G_bob]
#1052429
08/14/11 06:01 AM
08/14/11 06:01 AM
Thumperdart
State of confusion
Had the exact problem w/my Hookers and my buddy at Howards Muffler patched and welded it up and it`s fine. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: G_bob]
#1052430
08/14/11 09:32 AM
08/14/11 09:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Make sure you drill a stress reliever hole at the ends of the crack before welding EDIT Also if the flange isnt cut between the end pipes and the center pipes you should... it reduces the stress on the pipes allowing them to grow easier ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1052433
08/14/11 09:16 PM
08/14/11 09:16 PM
G_bob
Riverside, Ca
What's funny is that on these headers, number seven tube is a slip fit that goes around the steering column. It's flange is separate from the rest and there "shouldn't" be any stress on it. It being the slip fit tube should make it fairly easy to get out in order to fix it. ![](/ubbthreads/images/graemlins/luck.gif)
