Re: Ever bolt on heads without dowel pins in the block?
[Re: Baxter61]
#1051835
08/13/11 05:57 AM
08/13/11 05:57 AM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
I have put a head on without dowel pins but it was a straight six Ford. As mentioned earlier it's easy enough to make them from either a bolt or some weld rod.
