reducing installed height .090"? #1051053
08/11/11 11:19 AM
08/11/11 11:19 AM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
Would there be any issue using a spring with a 1.950 installed height set up at 1.860? This would be a beehive spring and would still end up .110 from coil bind.
Thanks!
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: reducing installed height .090"? [Re: Fishmarket] #1051054
08/11/11 12:07 PM
08/11/11 12:07 PM
Out of the State of Confusion
blue_stocker Offline
You might check Comp Cams and Crane Cams' retainers and 10* locks as they both make std, +/-.050" locks and various other parts plus the springs shims; however the big question is, do you want to increase the spring pressure that much? If so, check them out as they're std production items.
Re: reducing installed height .090"? [Re: Fishmarket] #1051055
08/11/11 12:50 PM
08/11/11 12:50 PM
Thanks!
None that I can thank of, I have shimmed many sets with .090 or more thick shims If you have aluminum heads make sure to use a harden spring seat or spring cup first and then shims I have started to put the shims under the cups or seats now instead of directly under the springs Make sure and use the wide shims that as wide as the cup or seat.
Re: reducing installed height .090"? [Re: blue_stocker] #1051056
08/11/11 04:51 PM
08/11/11 04:51 PM
Essex, Ont., Canada
Essex, Ont., Canada
1.860 is with a +.050" retainer, an ID locator and the increased spring pressure is a plus. I always put the shims under the locator.
