gm mini 1 wire alt #1050962
08/11/11 02:27 AM
08/11/11 02:27 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
does anyone know a good (cheap) source to buy a gm 1 wire mini alternator? Or something comparable? I have a toyota 93-94 4 runner alt but its no good. my cuda has a RB and a motor plate so i need the mini so it will fit...
any good setups? i would like something internally regulated, and has a easy hookup. I thought the toyoyta ones would help with the lights at idle.
unfortunately i got it used and it was no good. so i am thinking gm 1 wire. any thoughts, experiences, etc???
I don't have any crazy demands on it, electric fan, fuel pump, lights, radio (maybe), the basic stuff, i figure a 60 amp would be plenty.
Re: gm mini 1 wire alt [Re: 8urvette] #1050963
08/11/11 03:32 AM
08/11/11 03:32 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
also i see some true 1 wire alternators, they claim to run a constant 14 volts, this would not work for street use right? don't i need a 1 wire that actually has a power and sense wire?
Re: gm mini 1 wire alt [Re: 8urvette] #1050964
08/11/11 04:48 AM
08/11/11 04:48 AM
Finland
LUMI Offline
LUMI  Offline
Finland
how about Powermaster 8060
Re: gm mini 1 wire alt [Re: LUMI] #1050965
08/11/11 08:07 AM
08/11/11 08:07 AM
tboomer Offline
tboomer  Offline
I have an alternator off a 86 Park Avenue in my 64. It was checked by shop and puts out 86 amps..I also have motor plate and use a DMI alternator bracket. Works like a charm!
Re: gm mini 1 wire alt [Re: 8urvette] #1050966
08/11/11 08:27 AM
08/11/11 08:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you already had the Denso hooked up, why not get
a good one to replace it... I prefer the external
reg... I believe they kick in at a lower RPM
Re: gm mini 1 wire alt [Re: MR_P_BODY] #1050967
08/11/11 05:19 PM
08/11/11 05:19 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
im looking for it to be most cost effective, i have much more time than money....
Re: gm mini 1 wire alt [Re: 8urvette] #1050968
08/11/11 05:47 PM
08/11/11 05:47 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
1993 Geo metro with a V belt. about 40.00 from some autoparts stores. Tim
Re: gm mini 1 wire alt [Re: astjp2] #1050969
08/12/11 01:47 PM
08/12/11 01:47 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
I get my alt and mini starter both from DB Electrical of of Ebag. They are cheaper than our local parts houses, and work well. In fact I'm getting ready to buy both again for new Dakota race truck build. Here is a link (if it works) to alt;
http://cgi.ebay.com/ebaymotors/ws/eBayIS...e=STRK:MEWAX:IT
Re: gm mini 1 wire alt [Re: ETASPEN] #1050970
08/12/11 04:32 PM
08/12/11 04:32 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i looked at those on good ol bag, but was unsure about DB, i am into jetskis as well and they sell the cheapest starters, but i read more often than not they do not work. and dealing with them is a headache. I do NOT know from first hand experience, just what i have read.
thanks. I think ill try to go with the 90 ish toyota 60 amp again, something about being able to just go to the parts store to replace it makes sense, and they have great warranties here!
