Bent Pushrods?? How?
#1050635
08/10/11 04:49 PM
08/10/11 04:49 PM
Posts: 89 oregon
ramcharger1964
oregon
was coming home from car show doing about 55 mph. feels like carb starts to load and I get this very loud stacatto popping from the exhaust (left side). Pulled over, checked everything. Started back up fine and ran smooth but no oil pressure. Towed it home and found 2 bent pushrods in the valley from #1 piston. Might be worth noting that when I go highway speeds I am right at the point where the secondaries start opening and it seems to want to load up. This happened once before but it just cleared itself out when I gave it a little burst of throttle. I have yet to pull the manifold but the rockers look OK. This is a 499 max wedge cross ram roller cam and rockers. 12.5:1
Any ideas???????
Hell B!tch Racing Co.
Re: Bent Pushrods?? How?
[Re: Moparnut426]
#1050637
08/10/11 05:24 PM
08/10/11 05:24 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
The lifter popped outa the hole and you are loosing your oil pressure there. I have had a rocker shaft bolt come loose bent a shaft push rod fell out and the lifter popped out and had no oil pressure!
67' charger 499 RB
10.57 at 127
[Re: Moparnut426]
#1050639
08/10/11 05:41 PM
08/10/11 05:41 PM
dragram440
bigfork mn
Mine was just a hydrualic cam at the time. I was stumped until I pulled the intake.It was a real easy fix as long as you didnt run it with out oil pressure for awhile.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1050640
08/10/11 05:43 PM
08/10/11 05:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats what I would think... if both push rods on the same cyl are bent and gone then most likely both lifters ar laying in the valley with the push rods... now you need to pull the intake and also find out WHY did the push rods bend ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Dodgeguy101]
#1050642
08/10/11 06:15 PM
08/10/11 06:15 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
Too much carbon deposits on the pistons will remove clearances that could cause a valve to stub itself and take out the weakest link in the valvetrain.
Just sayin', that's all.
[Re: Dean_Kuzluzski]
#1050643
08/10/11 08:00 PM
08/10/11 08:00 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
That's what happened to me about 6 yrs ago. I snapped a push rod and bent the other one on the same cylendor. That happened at the end of a pass. My problem was the crane adjusters.
