Small Block Hyd. Roller Lifters....... #1049138
08/08/11 12:57 PM
08/08/11 12:57 PM
East Lansing, Michigan
O
OldHippie Offline OP
super gas
super gas
O
How "good" are the stock Hydraulic Roller Lifters in either a R/C LA block or a Magnum block? By good I mean is there a limit on Valve Spring in terms of pressure over the nose? A safe RPM limit? A limit on how much lift they will handle? I am not looking at something radical, just reliable through the occasional 6500 blast.
The Old Hippie Hisself
Re: Small Block Hyd. Roller Lifters....... [Re: OldHippie] #1049139
08/08/11 02:19 PM
08/08/11 02:19 PM
scratchnfotraction Offline
I have about 300,000 miles on a stock set,they were used,then swaped in a lunati Voodoo roller cam in 07'
they are with comp 901-16 springs and .485/.485 lift
been to 6200 rpm and no valve float so far with them.
all stock roller gear,roller lifters,stock hollow push rods,rockers
Re: Small Block Hyd. Roller Lifters....... [Re: scratchnfotraction] #1049140
08/08/11 06:00 PM
08/08/11 06:00 PM
O
super gas
super gas
O
Thanks, Scratchin'.
Re: Small Block Hyd. Roller Lifters....... [Re: OldHippie] #1049141
08/09/11 02:51 PM
08/09/11 02:51 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
IIRC board member jesse lackman has had them up to 8k with no problems, using relatively aggressive hughes cams....
check out
this thread
2017 Grand Cherokee Overland
Re: Small Block Hyd. Roller Lifters....... [Re: patrick] #1049142
08/09/11 03:32 PM
08/09/11 03:32 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Seen some stock mopar hyd rollers recently go 6800 with a cam that would not be considered aggressive
