Re: Oil splashing from dipstick tube
[Re: Pacnorthcuda]
#104893
08/14/08 05:14 PM
08/14/08 05:14 PM
Posts: 571 Western NC
68Bullit
Western NC
Okay, allow me to back up a little. I stopped the leak from the dipstick by adding breathers to both valve covers, then that stopped the leak from the tube. Now, I have oil coming from the driver's side breather that I installed and it's burning off the driver's side header, etc. The dipstick itself doesn't have an o-ring either. I want to remove both the breathers and somehow cork the dipstick tube also to keep the oil in the engine
[Re: 68Bullit]
#104894
08/14/08 05:18 PM
08/14/08 05:18 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
Ok well thats different. Now it sounds like you need to baffle the breather openings on the underside of the valve covers to help prevent oil from finding its way into the breather(s). IF you already have baffles, I would look for a different design of breather and I would be concerned about the amount of blowby passed the rings that may be occurring.
[Re: 68Bullit]
#104896
08/14/08 06:22 PM
08/14/08 06:22 PM
Posts: 32,992 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
You need a breather in one valve cover and a pcv in the other hooked to the carb. If you don't have excessive blow by then that shoiuld stop the leaks. If you don't let the system breath you will continue to blow oil everywhere. You can't seal the motor up and not expect it not to leak. Remember as the pistons move up and down you have pressure building up in the block. After all the are just big cups underneath.
[Re: stumpy]
#104897
08/14/08 06:24 PM
08/14/08 06:24 PM
Posts: 13,616 md
mopars4ever
md
[Re: 68Bullit]
#104898
08/14/08 07:52 PM
08/14/08 07:52 PM
Pacnorthcuda
Greg, here are some pics. Not sure about the baffle you are referring to, but here is a pic of the driver's side and inside the oil fill, then the pic of the breather that I put in there, then the passenger side breather. Didn't see what it looked like inside the valve cover on the passenger side.
1)So you don't have a PCV valve? You should. If not convert one of the breathers to a PCV 2)Under the breather(s)...do you see sheet metal very close to the hole in the valve cover or are you looking at rocker arms? If rocker arms, you should remove the valve cover(s) and install baffles--hopefully there are screw mounting bosses for that purpose in the VC castings. The baffles are just simpple sheet metal plates that allow the excess pressure to go around (and through the breather) without allowing direct-splash of oil into the breather.
Or do you have a LOT of blowby?
[Re: Pacnorthcuda]
#104900
08/14/08 08:10 PM
08/14/08 08:10 PM
68Bullit
Western NC
Okay, there is no sheetmetal there, only looking at rocker arms when the breather or oil fill cap is taken off. Here's what I just finished. I just drove the car and got it warm after I put the oil fill cap back on the driver's side, made sure the dipstick was sealed good inside the tube, and then put the passenger side breather back on. It seems to be putting out alot of air (from the breather) as well as light smoke, and I mean really light smoke. Do I have a problem here??? Car runs great. Good torque and power, and doesn't miss or run choppy at all. Oil pressure can be as high as 70-80 when starting off cold, and idles at around 20-25 when warm.
[Re: MoparforLife]
#104903
08/14/08 08:28 PM
08/14/08 08:28 PM
68Bullit
Western NC
Thanks for all the help guys. I need to order the pcv. As for the baffle, is it hard to make a baffle for the inner valve cover, or is it just shaping and forming some sheetmetal? And how do I attach it?
[Re: 68Bullit]
#104904
08/14/08 08:31 PM
08/14/08 08:31 PM
stumpy
Grand Prairie,Texas
PCV system, a rubber gromet in the valve cover with the pcv valve stuck in gromet and a hose to the large vacuum port on the base of the carb. The gromet, the hose, the pcv valve are all avaiable over the counter at the parts store.
[Re: stumpy]
#104905
08/15/08 10:33 AM
08/15/08 10:33 AM
Posts: 114 Iowa
clarkj
Iowa
I had the same problem as you are having in a 318 I rebuilt once. My engine would blow the dipstick up out of the tube, and also make oil drip out of my breather. Initially, I just had a breather on one valve cover with no PCV valve. I then put a PCV valve on the valve cover opposite of the breather, and my problems persisted. I was confused, because just like your engine, mine ran great, even with all of the oil problems.
I yanked the motor thinking maybe I had a broken ring or that maybe I put on on upside down, or even forgot to put on one...I've seen it done. I got to looking and all of my rings seemed fine, but my hone job looked pretty crappy after I got to looking closer. I had just used one of the the cheapy three-stone hones, and my bores still looked pretty slick. I borrowed a good bead hone, worked on it with that, and re-ringed it...problem solved.
It was frustrating to see that my negligence caused me that much time and money to fix.
