Re: What's the differences in the 66'/67'Satellites ?
[Re: Sidewinder]
#1048445
08/06/11 10:57 PM
08/06/11 10:57 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
There are quite a few subtle differences - where to start?
EXTERIOR: You said you know about the front. Otherwise: - Trunk panel and tail lights totally diff. - Side trim on a '67 is different. All aluminum and runs at a different height than '66's. - I don't think '66's could be had with the directional light 'bullet' on top of the front QP's. - Hood ornaments are different. INTERIOR: - The 'western scroll' on the door and rear QP panels run horizontal on a '66 and vertical on the '67s. - Seats on a '66 had two strips of 'western scroll', the '67s only one. - The speedo on a '67 doesn't have the plastic 'Plymouth' emblem covering the needle hub. - Horn rings were diff. Hub emblems were red on '66s. Black on '67s.
OTHER MISC: - '66s usually had single circuit brake MCs. '67s were dual.
There are sure to be other things. -Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
