Changing cams using break in oil #1048163
08/06/11 02:00 PM
08/06/11 02:00 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Using royal purple breakin oil on a new cam.How long before i change the oil to regular royal purple?would 10w 40w be ok to change to? 440 engine hughes cam.
Re: Changing cams using break in oil [Re: gtx69] #1048164
08/06/11 05:18 PM
08/06/11 05:18 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
I put around 100 road miles ,Then went back to GTX 10-40 I think you can run up to 2500 miles . I keep it and reuse it over and over . Last three engine. All did ok!!
Re: Changing cams using break in oil [Re: gtx69] #1048165
08/06/11 09:07 PM
08/06/11 09:07 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
1000-miles on the break-in oil. Then go with the least thick motor oil that still provides acceptable oil pressure. Start with 10W-30 and see how your accurate oil pressure gauge responds.
Re: Changing cams using break in oil [Re: CompSyn] #1048166
08/07/11 09:57 PM
08/07/11 09:57 PM
Canfield,Ohio,USA
gassy66 Offline
gassy66  Offline
Canfield,Ohio,USA
Amsoil now has fully synthetic Engine Oil with
Zinc added, especially for flat tappet Engines..
I intend to put It in My 440 after i reach 1k miles on the break in Shell Rotella with Lucas
Zinc additive..
Re: Changing cams using break in oil [Re: gassy66] #1048167
08/07/11 10:12 PM
08/07/11 10:12 PM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
Which Amsoil is it exactly they seem to make 100 different kinds
PLAZ
Re: Changing cams using break in oil [Re: plazomat] #1048168
08/07/11 10:51 PM
08/07/11 10:51 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
PLAZ
Good question. Here's Amsoil's Flat Tappet Cam Technical Service Bulletin - CLICK HERE
Moparts - AMSOIL Engine Assembly Lube - link
Moparts - AMSOIL (SAE 30) Break-In Oil – link
Moparts - AMSOIL Z-ROD Synthetic Motor Oil – link
Save 15-to-25% by going to this LINK
Re: Changing cams using break in oil [Re: CompSyn] #1048169
08/08/11 01:13 AM
08/08/11 01:13 AM
plazomat Offline
plazomat  Offline
Thanks - any discount for Canadians?
Plaz
Re: Changing cams using break in oil [Re: plazomat] #1048170
08/08/11 09:36 AM
08/08/11 09:36 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Plaz
Yes, Canadians can get the same discount. Although there is a separate form for Canadians.
Also, depending on where you are in Toronto, once you have your PC account in the system, you can call your order ahead to the Toronto Amsoil distribution center and then pick it up not paying a dime in shipping cost, very cool.
