44-46re swap without pcm #1048131
08/06/11 11:28 AM
08/06/11 11:28 AM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
has anyone installed a 44-46 re without using a pcm to control it, is there a way to wire it into a 60's mopar? thanks
70 beep beep 383 N96 4spd 68 beep beep, eddy headed 383 4 spd 73 340 chally 73 340 duster
Re: 44-46re swap without pcm [Re: 1badrt] #1048132
08/06/11 11:45 AM
08/06/11 11:45 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The RE series transmissions have no governor persay, as it relies on PCM inputs/outputs to control shift points , torque conv lockup and OD function
And I know of no aftermkt avail controllers to make it work.
RE series trans would be more trouble than it's worth as opposed to a RH series trans which still uses a mechanical governor , just electronic to control OD function
Re: 44-46re swap without pcm [Re: 1badrt] #1048133
08/06/11 03:32 PM
08/06/11 03:32 PM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
thanks for the info, i really apreciate it
