haden ele.fan thermostat?
#1047779
08/05/11 08:34 PM
08/05/11 08:34 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i bought one today and have it all wired up except 2 wires but have a ? one of the wires go to keyed 12 volts ,no biggie but i ran out of that color wire (yellow) the othet wire says to run to ac so when you turn ac on it will come on and if you dont run to a toggle comes on at 180 off at 170 is the wire to toggle to just over ride?if so can i leave it off?heck if i wanted to run it off a toggle switch i could of wired it up with one and no nead for a thermostat
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: haden ele.fan thermostat?
[Re: Andrewh]
#1047781
08/05/11 09:20 PM
08/05/11 09:20 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
what happend to it coming on at 180 and shuting off at170 on its own?
[Re: Andrewh]
#1047783
08/05/11 11:18 PM
08/05/11 11:18 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The AC override is to cool the condensor, not the radiator. This is for the condition your ac is cycling and your radiator does not need cooling from the fan.
As for the automatic temperature. Those numbers seem low. The OFF temp must be higher than your thermostst temperature.
[Re: Magnum]
#1047784
08/06/11 12:54 AM
08/06/11 12:54 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
good then i wont worry about hooking up a toggle switch the paper work say will come on when temp reachs 180 and will stay on till temp reaches 170
[Re: Andrewh]
#1047786
08/06/11 12:22 PM
08/06/11 12:22 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
i never use a thermostat in any of my older car for almost 30years this one wont be any differnt iv never had a prob related to the cooling
