'01 Caravan 3.8 Engine Swap? #1047410
08/05/11 02:49 AM
08/05/11 02:49 AM
Polson, MT
DoctorDiff Offline OP
Polson, MT
I'm thinking about buying an '01 Caravan with a bad 3.3 engine.
Will a 3.8 engine interchange? Is there a specific range of years that will swap easily? How involved is this swap?
Re: '01 Caravan 3.8 Engine Swap? [Re: DoctorDiff] #1047411
08/05/11 03:52 AM
08/05/11 03:52 AM
Las Vegas NV
Revhard Offline
Revhard  Offline
Las Vegas NV
What is the motor #s? I know the earlier ones were the 6g72. Lmk and I'll get back to ya'
Re: '01 Caravan 3.8 Engine Swap? [Re: Revhard] #1047412
08/05/11 08:49 AM
08/05/11 08:49 AM
Northern VA
1970440six Offline
1970440six  Offline
Northern VA
It will set a check engine light if you use a different motor. The code will be too rich or lean, it wont work without changing computer.
Re: '01 Caravan 3.8 Engine Swap? [Re: 1970440six] #1047413
08/05/11 11:48 AM
08/05/11 11:48 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It will run fine with the 3.3 computer. Been there done that. I have done it with 5.2 and 5.9s also and every time it works just fine. When you do swap the computer later on it makes more power but the computer needs to be programed with the VIN and miles on the vehicle or there will be codes for it. The computer can change fuel trim up to 25% before a code comes on for rich or lean and a 3.8 does not use 25% more fuel, according to the EPA there is like 1 mpg different between the two.
Are you just thinking it would be cool to have a few more HP? A gear swap in the 604 tranny is pretty easy too
If you need any assistance give me a PM, I am just at the other end of the lake
Re: '01 Caravan 3.8 Engine Swap? [Re: DoctorDiff] #1047414
08/05/11 12:01 PM
08/05/11 12:01 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Cass ...I would stay-away from an 2001 uNless you were going to convert it to a RWD mid-engined 440 like i am going to do ...
There are SEVERE transmission issues with the 3rd GEN Caravans uNtil the 2003 model year.
Re: '01 Caravan 3.8 Engine Swap? [Re: HotRodDave] #1047415
08/05/11 12:43 PM
08/05/11 12:43 PM
Polson, MT
Polson, MT
I would like to make a work van out of it. Because I constantly overload the vehicle, the extra torque may be beneficial.
I haven't had a chance to look at the van, so I don't know the VIN yet.
I assume an '01-'07 3.8" engine will bolt in place. Will a '90s 3.8" swap? I would definitely have another transmission built at the time.
Re: '01 Caravan 3.8 Engine Swap? [Re: DoctorDiff] #1047416
08/05/11 12:53 PM
08/05/11 12:53 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
torques convertors as well as final drive ratios in the trans are different between the 2
engines will vary with years of manufacturer
Re: '01 Caravan 3.8 Engine Swap? [Re: gtx6970] #1047417
08/05/11 02:18 PM
08/05/11 02:18 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Yo have to be aware of changes from a SBEC controlled engine and a NGC controlled engine. They used different flexplates and camshaft tone rings.
Re: '01 Caravan 3.8 Engine Swap? [Re: gtx6970] #1047418
08/05/11 03:45 PM
08/05/11 03:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The one I switched used the same year engine, just got the bigger one so I don't know about what years fit what. I would just try to find the same year motor and drop it in.
A salvage yard would be able to tell you what year 3.8 can swap with an 01 3.8 van and I would feel safe buying one within that year range.
Re: '01 Caravan 3.8 Engine Swap? [Re: HotRodDave] #1047419
08/05/11 03:47 PM
08/05/11 03:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Just made a call for you, any 3.8 from 01-03 would be a direct swap.
Re: '01 Caravan 3.8 Engine Swap? [Re: HotRodDave] #1047420
08/05/11 10:02 PM
08/05/11 10:02 PM
Polson, MT
Polson, MT
Thanks for the infomation.
