Do I NEED a Dana?
#1047076
08/04/11 11:35 AM
08/04/11 11:35 AM
Posts: 834 Beavercreek, Ohio
OA5599
Beavercreek, Ohio
Yes...I know. This there is nothing left of this dead horse to beat. But I notice a lot of guys getting away with an 8-3/4, so I'm looking for advice about my own personal application. 69 Cuda weighs around 3550 lbs with driver. 418 SB that gets it down the track 7.30 at 94.5 1/8th and 11.30s or so 1/4 at 115ish. 60 ft with M/T E/T streets is 1.62-1.63. Stock suspension. 727 with a "tight" 10" converter. Will footbrake 2200ish if pushed hard. Launched at 2000. This car sees 95% street/cruise time. Goes to the track 4-5 times a year at the most. At the moment, it has a stock 8-3/4 with 3:91 gears. A dana will be a huge snowball effect and will run me at least $3-4k for the swap. Any suggestions of what to do to my 8-3/4 to put up with this? Does it need a spool, etc? Remember, it IS a street car most of the time. Is it just a question of "when" not "if" it will let go? If you need anymore info, just let me know. I would really like to avoid the Dana route if I can, so I am looking for your honest opinions based on your experiences. Thanks
Re: Do I NEED a Dana?
[Re: OA5599]
#1047080
08/04/11 12:05 PM
08/04/11 12:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm not saying it will blow or not but if I were to keep the 8 3/4 I would back brace it, a set of decent axles and do the aftermarket carrier caps.... if you didnt go with the caps I would run load bolts on the caps
[Re: MR_P_BODY]
#1047081
08/04/11 12:08 PM
08/04/11 12:08 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Mr. P when you do the caps don't you have to have it line bored?
[Re: Mr.Yuck]
#1047082
08/04/11 12:14 PM
08/04/11 12:14 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I used to run an 8-3/4 in my 440 dart 11.09 best at 121mph but my car was 3270 with me, yours is quite heavy for an A body, i also used moser shafts, 742 centre. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: OA5599]
#1047083
08/04/11 12:15 PM
08/04/11 12:15 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I dunno, I`ve only been beating on mine for 20 years or so(not this exact set)so it`s hard to say if yours will live. Go have some fun and at LEAST put some after market axles it it and I personally run Dutchmans.
[Re: tboomer]
#1047084
08/04/11 12:21 PM
08/04/11 12:21 PM
OA5599
Beavercreek, Ohio
Starting to feel a little better. I an not familiar with what back bracing is. Still a bit of a "noob". I would need brakes (I'm guessing I couldn't use my current ones with the Dana)...which leads to big bolt pattern, which leads to new wheels, etc.
[Re: Mr.Yuck]
#1047085
08/04/11 12:23 PM
08/04/11 12:23 PM
MR_P_BODY
They need to be machined but not line bored(theres threads in there)... just milled
[Re: OA5599]
#1047087
08/04/11 12:27 PM
08/04/11 12:27 PM
MR_P_BODY
Starting to feel a little better. I an not familiar with what back bracing is. Still a bit of a "noob". I was basing 3-4k off of Dr Diff's site for a complete Dana 60 setup costing $3000. Then I would need brakes (I'm guessing I couldn't use my current ones with the Dana)...which leads to big bolt pattern, which leads to new wheels, etc.
Here's a back brace on a 9"... same set up
[Re: OA5599]
#1047090
08/04/11 12:47 PM
08/04/11 12:47 PM
MR_P_BODY
By the way... I'm still running a 8 3/4 in my car... my car is light but I run a 1.19 60' in the high 8s... back braced and now I run a alum center that has big caps... even my Strange axles have twist in them
[Re: B G Racing]
#1047091
08/04/11 12:55 PM
08/04/11 12:55 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have a couple dozen passes on mine. I have 35 spline axles, spool, and 3.91 motive gears with a back brace. Car weighs 3800 lbs with me in it. Foot brake 1.51 best 60' 10.63 @ 128 mph. The rest of the runs are between 10.63 and 10.80. I have had it apart to check everything out two times now and everthing looks like new still. Im going to keep running mine for now.
67' charger 499 RB
10.57 at 127
[Re: OA5599]
#1047092
08/04/11 01:09 PM
08/04/11 01:09 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
BTW my Dana was less than $2000 shipped, this with a spool and race axles. Look here http://www.strangeengineering.net/catalog/072.html
[Re: viperblue72]
#1047094
08/04/11 07:39 PM
08/04/11 07:39 PM
Posts: 553 Kentucky
clovis
Kentucky
If you are going to buy axles, caps, backbrace and maybe even a spool, I would think about spending toward the Dana. I just put a Dana together for about $1,300. That included buying a junk yard rearend, having it cut, axles, housing ends, gears(used), spool, yoke, u-joints, pads, bearings and drive shaft shortened.
If you compare the expenses of what you are going to add to your 8 3/4 (axles-$350, backbracing-$100, caps & milling-$150) $600 to the cost of the dana $1300 minus what you can get for your 8 3/4 as it sits say $500, $800 net, it is only $200 to upgrade.
My car (3300lbs) was run a long time on a 8 3/4 with stock axles at high 10's. I would check them alot but never a sign of a problem. So as I said from the start if I was going to buy axles and maybe a spool and was thinking about any power increases I would go ahead and spend my money towards the dana, but as you sit today you will probably be fine with what you have.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#1047095
08/04/11 08:07 PM
08/04/11 08:07 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I ran a 8 3/4 under my Demon it was probably 3400 lbs with me in it. It had a billet cap and stock axles. It was going 6.40's in the 1/8 with a 1.36 60 ft on a 100 shot nos.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
