Taking out a 8-1/4 and installing a 9-1/4 #1045925
08/02/11 04:26 PM
08/02/11 04:26 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Ok Guys I'm getting ready to take my 8-1/4 out of my 73 Roadrunner and installing a 9-1/4. Can somebody walk me through this ?
The 9-1/4 had the perches cut off of it before I got it. I have new perches but I don't think they will work with the ISO mounts that I have and plan to keep. I might need to cut the perches off the 8-1/4 and re-use them. Welding them on is not a problem ( I'm a good welder)
The things I need help with are :
1. Setting up the car ( should the chassis be level ?)
2. When I set the rear end should the weight of the car be on the rearend with jack stands under the axle?
3. When I set the pinion angle what should it be ?
4. Where should I measure the pinion angle from ?
I have done this before but never paid attention to the pinion angle I just centered it side to side and eyeballed the pinion so it lined up with the trans and it's worked fine. After reading some of the posts here it seams that pinion angle is more important than I thought 20 years ago.
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: 73rrak] #1045926
08/02/11 07:32 PM
08/02/11 07:32 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Nobody ??? WOW !!!
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: 73rrak] #1045927
08/02/11 07:34 PM
08/02/11 07:34 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Give it some time, folks are just getting out of work. I know there are folks here that can help.
I have mechanical Aptitude.
I can screw up anything.
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: bboogieart] #1045928
08/02/11 07:38 PM
08/02/11 07:38 PM
dogdays Offline
dogdays  Offline
The output shaft of the transmission and the pinion should be parallel to each other when the car is supported by the wheels or by four jackstands (two under the rear axle) that put the car in a level position.
Others may have a better idea, they'll post.
R.
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: dogdays] #1045929
08/03/11 01:36 AM
08/03/11 01:36 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I remember reading about setting it with an angle finder I hope I didn't waste a whole $10 on my Harbor Freight angle finder
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: 73rrak] #1045930
08/03/11 12:35 PM
08/03/11 12:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Why can't you set it up the same as the 8-1/4" housing?
I understand the pinion pokes out farther but that shouldn't make a huge difference.
- Stu Harmon
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: feets] #1045931
08/03/11 05:11 PM
08/03/11 05:11 PM
dogdays Offline
dogdays  Offline
Aren't the 8 1/4 and 9 1/4 the same length from centerline of axle to u-joint?
R.
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: dogdays] #1045932
08/03/11 06:02 PM
08/03/11 06:02 PM
Windsor, Ontario
P
project74 Offline
project74  Offline
P
Windsor, Ontario
R.
Indeed they are. The 9.25 is a cheaper upgrade than an 8.75 and is still plenty strong if you're not going to be swapping gears. Direct bolt in.
1970 Fury III, 318, 4 dr hardtop, aka "The Fridge"
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: project74] #1045933
08/03/11 06:15 PM
08/03/11 06:15 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If that's the case, measure the 8-1/4 rear and stick the perches on the 9-1/4 in the same place and angle.
- Stu Harmon
Re: Taking out a 8-1/4 and installing a 9-1/4 [Re: feets] #1045934
08/04/11 02:08 AM
08/04/11 02:08 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I was thinking about doing that. Measuring the distance from the floor to the yoke on the 8-1/4 then set the yoke on the 9-1/4 in the same place. This should get me in a good spot right? Will the pinion snubber from the 8-1/4 fit the 9-1/4 ?
