Re: Taking out a 8-1/4 and installing a 9-1/4
[Re: 73rrak]
#1045926
08/02/11 07:32 PM
08/02/11 07:32 PM
Posts: 340 Alaska
73rrak
Alaska
[Re: 73rrak]
#1045930
08/03/11 12:35 PM
08/03/11 12:35 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Why can't you set it up the same as the 8-1/4" housing?
I understand the pinion pokes out farther but that shouldn't make a huge difference.
[Re: project74]
#1045933
08/03/11 06:15 PM
08/03/11 06:15 PM
feets
Senior Management
Senior Management
Irving, TX
If that's the case, measure the 8-1/4 rear and stick the perches on the 9-1/4 in the same place and angle.
