hard brake pedal ,no stop #1045440
08/01/11 11:14 PM
08/01/11 11:14 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I did a disc conversion on my friends 70 Coronet R/T. Stock 70 pin type calipers and master. Car doesn't want to stop even at idle. Pedal feels normal until its about half way down. Then it feels like a brick is under the pedal. You can't move it further. All stock stuff. Pedal linkage is correct,tried 2 boosters,2 master cylinders(1 1/8" and 1"). Rear wheels can be turned by hand with brake applied unless it has extreme pressure is applied. I actually have this same condition with a 66 coronet. It has 4 wheel drum with a converted dual master. Otherwise all stock.
Any ideas?
Doug
Re: hard brake pedal ,no stop [Re: dvw] #1045441
08/01/11 11:59 PM
08/01/11 11:59 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
on the 66 i think you need a master cyl from a c body to get the correct preasure to the wheel cyl .
and maby some larger wheel cyl .
does the 70 have a proportioning valve ?
also old hoses cause problems !get new !
Re: hard brake pedal ,no stop [Re: dvw] #1045442
08/02/11 12:01 AM
08/02/11 12:01 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
What pads did you get?
Re: hard brake pedal ,no stop [Re: dvw] #1045443
08/02/11 12:08 AM
08/02/11 12:08 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Did you adjust the threaded pushrod on the booster before installing the master cylinder,...clearance should be approx .060....you may bottoming the pedal, but if the airgap between the pushrod and the master's piston is a "mile' away, it's just not moving enough fluid to create pressure
Re: hard brake pedal ,no stop [Re: DAYCLONA] #1045444
08/02/11 07:38 AM
08/02/11 07:38 AM
Adelaide Australia
P
peter Offline
peter  Offline
P
Adelaide Australia
i have just done the same thing and have the same problem
ive in stall hemi style brake booster and disc brakes
when i drive the car ive got use both feet to try and get it
to pull up
pete
Re: hard brake pedal ,no stop [Re: peter] #1045445
08/02/11 10:08 PM
08/02/11 10:08 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The push rod adjustment has been to long,to short,and right on. Pads are not the issue,it won't even stop well at an idle. I believe the booster is bottomed before the master has enough travel. Could a drum booster have shorter travel than a disc booster? Come to think of it this is the 3rd car I've known of with this problem. The 3rd car was a 69 Hemi Charger Originally power drum brakes converted to disc. The booster was removed and converted back to manual disc. Problem solved. Removing the power brakes on this car is not an option.
Doug
Re: hard brake pedal ,no stop [Re: dvw] #1045446
08/02/11 11:30 PM
08/02/11 11:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Doug
Let's assume everything is A-OK, as far as the install and mechanical soundness of the parts,...is this car an automatic?....a healthy cam lift?, if so what is the engine vac at idle?, if it's under 12"vac, you need a vacumm resv./assist pump,...been there done that
Re: hard brake pedal ,no stop [Re: DAYCLONA] #1045447
08/03/11 05:35 AM
08/03/11 05:35 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
After what my brother just went through with his drum brakes on his Barracuda, I wouldn't overlook the pads depending on where they came from. He put new drums and shoes on the front of his 65 and it would not stop, like scary not stop. He pulled them back down and the shoes still looked new, he slapped his old shoes back on just to see and voila, stopping on a dime. A new set of Wagner shoes and he's good to go. The offending shoes were from Autozone.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: hard brake pedal ,no stop [Re: phantomx] #1045448
08/03/11 03:42 PM
08/03/11 03:42 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello, Did a 70 Challenger last year, and just today, finished a 71 Cuda...exact issue you are having!! 1st the Challenger. If you are using the valves from a 70 (two separate valves) make darn sure the lines are hooked correctly. Believe me, you can hook them up wrong! That was my problem. Could not get the car to bleed. Had a hard pedal tho. Switched the lines to the correct positions, problem solved. Now, the 71 Cuda from today. Kit came from Inline. It is to use the 70 valves. Shouldn't make a difference tho. Anyway, couldn't for the life of me get fluid to the rear. Bled, and bled..no luck. Ended up being a collapsed rear hose. Why it worked with the drum...I don't know. Replaced hose, all's good.
When you are bleeding, crack open fitting closest to master and work your way back. I bet you'll find the problem. Take care, Jeff
Re: hard brake pedal ,no stop [Re: DAYCLONA] #1045449
08/03/11 06:28 PM
08/03/11 06:28 PM
Under My Car
Mopar_Country Offline
Under My Car
Doug
Or manual brakes. I have the same issue, I'm about to drop the booster.
Re: hard brake pedal ,no stop [Re: Mopar_Country] #1045450
08/03/11 08:17 PM
08/03/11 08:17 PM
At this point, me I'd hookup a 1500-2000 psi gauge to the 4 corners & see if it's a psi or a pad/lining prob. You can get a 5" round gauge in that range for 10-$15 plus need several fittings to adapt it (I think the gauge is 1/4" male NPT)
Re: hard brake pedal ,no stop [Re: phantomx] #1045451
08/03/11 09:46 PM
08/03/11 09:46 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
Travis..
How are the carbon metallic shoes Firm Feel sells ?? Ive been having poor stopping on my street rod, Im sure its the shoes on it
Re: hard brake pedal ,no stop [Re: stateline] #1045452
08/03/11 10:47 PM
08/03/11 10:47 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Cam is very mild,218@.050". Has well over 12" vacuum. There is plenty of fluid flow out of the rear bleeders. Pads were switched last summer with no improvement. I'm going to rig up a pressure gauge this weekend. It does have the stock drum brake valves. I may rig a temporary line from the master to the rear axle as well.
Doug
Re: hard brake pedal ,no stop [Re: dvw] #1045453
08/04/11 12:06 AM
08/04/11 12:06 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Doug
get rid of the drum distribution block, use the correct proportioning valve,... are you using a drum/drum master or the correct disc/drum master?????????
Re: hard brake pedal ,no stop [Re: DAYCLONA] #1045454
08/04/11 11:26 PM
08/04/11 11:26 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I've tried both. 1 1/8" disc master. Also 1" drum master. And yes I removed the residual check valve 1st. Both felt the same. But your right the drum valve may be an issue. However car #2 with this problem was converted from a single master to a dual master, the original drum brakes are still on that car. So this is not a disc only problem.
Doug
Re: hard brake pedal ,no stop [Re: peter] #1045455
08/05/11 02:26 AM
08/05/11 02:26 AM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
CORRECT HEMI POWER BRAKE UNITS WORK VERY VERY WELL
Re: hard brake pedal ,no stop [Re: dvw] #1045456
08/05/11 02:31 AM
08/05/11 02:31 AM
TheRamMan Offline
TheRamMan  Offline
you must have the correct parts ,functioning correctly ,for it to work correctly..i will help you 817 691 5996
wayne TRM
Re: hard brake pedal ,no stop [Re: 1969RR] #1045457
08/05/11 02:34 AM
08/05/11 02:34 AM
TheRamMan Offline
TheRamMan  Offline
VERY SMART ...YOUR HOSE REASONING
Re: hard brake pedal ,no stop [Re: TheRamMan] #1045458
08/05/11 02:50 PM
08/05/11 02:50 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
A POWER DRUM booster will not work with disc brakes!
We just went through this on a 68 Charger R/T. We put all of the disc brake parts on the car except for the original Power drum booster that was originally on the car. We had a hard pedal but the car was not stopping well. Changed to a Power Disk booster and stops great now.
Brad
Dorn Restorations
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: hard brake pedal ,no stop [Re: BradD] #1045459
08/07/11 09:34 AM
08/07/11 09:34 AM
Northern NJ, U.S.
71X-mark Offline
71X-mark  Offline
Northern NJ, U.S.
How can you tell the difference between the drum and disc boosters? Don't they look the same?
