Page 3 of 3 1 2 3
Re: How do YOU slow down YOUR car for index racing? [Re: Chris'sBarracuda] #1045103
08/04/11 09:10 AM
08/04/11 09:10 AM
Arizona
Chris'sBarracuda Offline
Arizona
Don..
Here is what I used to do...
Welded tubing in the trunk, that would fit regular weight lifting weights.
Drilled holes in the tubing to put pins just above each weight.
This way, I could add whatever amount of weight I wanted, where I wanted..
Even passed tech. Just have to have the correct size pins or bolts.
If I can find a pic, I will post it..
Chris..
Re: How do YOU slow down YOUR car for index racing? [Re: Jeepmon] #1045104
08/04/11 09:41 AM
08/04/11 09:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Since we're on the subject.. how much timing can you pull out of the motor and still be safe?
I didnt change my timing... I went the direction I
did so I could run 2 classes so I wanted a quick change
set up with minimal work
Re: How do YOU slow down YOUR car for index racing? [Re: MR_P_BODY] #1045105
08/04/11 11:43 AM
08/04/11 11:43 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks Chris, the car is already designed for easy and legal weights in the trunk...
Re: How do YOU slow down YOUR car for index racing? [Re: MR_P_BODY] #1045106
08/04/11 11:46 AM
08/04/11 11:46 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Mike, I ordered the Moroso throttle stop thingy from Summit.. its the one that looks very much similar to yours and its supposed to arrive later today.. I'm not sure I will need to use it, but if I do, at least I'll have it..
Also, I've always been curious how much timing you can take out and not hurt the motor, so this seemed like the perfect opportunity to fish for an answer..
Re: How do YOU slow down YOUR car for index racing? [Re: Al_Alguire] #1045107
08/04/11 11:48 AM
08/04/11 11:48 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Spot dropping is actually a VERY good idea IMO. Provided you have the time to test and find the right spot.
Hopefully, everything stays calm around here and we can hit up the Friday night TnT at Sac.. Thanks for your help Al...
Re: How do YOU slow down YOUR car for index racing? [Re: Jeepmon] #1045108
08/04/11 11:54 AM
08/04/11 11:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I tried slowing down a friends car with timing... we
pulled 6 or 8 degrees and it slowed very little...
it tends to burn way to hot in the pipes... dont know
what its doing to the exhaust valves and seats
Page 3 of 3 1 2 3
