Re: Engine or Chassis Dyno
[Re: beepbeepdon]
#1044812
08/01/11 01:36 PM
08/01/11 01:36 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
My friend is trying to get me to go to the chassis dyno in the next week or two and I was also wondering if this is money well spent? I would be just working with timing and jetting which I have never done anything with since I put it together?
67' charger 499 RB
10.57 at 127
[Re: Dunnuck Racing]
#1044816
08/01/11 02:32 PM
08/01/11 02:32 PM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
I prefer engine dyno's which is the reason I bought one. A chassis dyno is fine if you have a good operator,and use it for tuning and not to try for bragging rights numbers. If you use either one as a tool like it is intended and don't get caught up in the numbers game,it can be useful. Keith
if the motor is already in your car then go for the chassis dyno. an upside too is they are usually a bit cheaper.
[Re: beepbeepdon]
#1044818
08/01/11 03:23 PM
08/01/11 03:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They both have their place... if you want to tune the engine for cruise conditions you need a chassis dyno ... but if you run a loose converter most of the lower rpm readings are sorta useless(if your looking for the torque/HP numbers)
[Re: sshemi]
#1044821
08/01/11 05:39 PM
08/01/11 05:39 PM
dragram440
bigfork mn
Could I get a decent idea of how much the converter is slipping? My car runs a crappy 60', and I think my plugs look a little lean but im not real great at reading plugs. A normal weekend at the track I only get 5 runs in 3 days so I hate to mess with it to much or I never know what to dial! Might give it a shot for $125 for a hour. I would like to get it running lower into the tens so I can stop thinking about making it faster.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1044822
08/01/11 05:54 PM
08/01/11 05:54 PM
MR_P_BODY
Sure if you know the exact RPM you cross the line at, tire size and gear then you can figure the slippage
