Repairing an 71 Imp instrument cluster
#1043893
07/31/11 02:34 PM
07/31/11 02:34 PM
Posts: 1,091 Czech Republic, Central Europe
BobAsh
A friend of mine has got a 1971 Imperial Lebaron and no gauges except for the speedometer are working - mechanic tried to fix them, but he can't seem to make them work together with sensors.
Does anyone here have some experience repairing these things? Is it possible to get replacement electronics for the gauges or fix it, or is it better just to slap a few autometer gauges under the dash?
Gettin' old iron accross the pond...
Re: Repairing an 71 Imp instrument cluster
[Re: BobAsh]
#1043896
08/01/11 10:54 AM
08/01/11 10:54 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My 72 Imperial has the same problem. Only the speedo and oil pressure gauge work. Even the clock is dead. I think it's a voltage limiter thing. I haven't worried too much about it since mine isn't really a driver yet. I do have the factory manuals and will run down the problem when I rebuild the car.
[Re: chargincharles]
#1043898
08/01/11 03:21 PM
08/01/11 03:21 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I probally have a few complete dashes in the garage.I pulled them when I scrapped my Imps.They signal sentrys even worked as did the hard to find switches.Typically if one gauge works the limiter is good.69 to I believe 71 or 72 all used the same dashes.Rocky
Chrysler Firepower
