440 crank? #1043592
07/30/11 11:49 PM
07/30/11 11:49 PM
USA
Lawn Monkey Offline OP
USA
70, 440 crank is there an automatic crank and a manual crank or just one standard crank
Re: 440 crank? [Re: Lawn Monkey] #1043593
07/31/11 12:18 AM
07/31/11 12:18 AM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
Chrysler motors usually were not drilled for a pilot bushing. How many chrysler imperials did you know with a 4 speed!
Now ask me how I know that.
Built my first engine back in 74 for my GTX. got a junkyard 440 to build. engine all done on the engine stand and now its time to install the pilot bushing.......NOT.
Re: 440 crank? [Re: bumps440] #1043594
07/31/11 05:06 AM
07/31/11 05:06 AM
USA
USA
bumps440 good post as would have it I have a Chrysler Newport 440 as my base for my build. I assume its just a little machine shop work to install a pilot bushing?
Re: 440 crank? [Re: Lawn Monkey] #1043595
07/31/11 07:23 AM
07/31/11 07:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It may be that simple , if the shop can handle the job . the cranks are drilled but not finished reamed to size and or depth . the simple way around it is to use the late model pilot bushing that fits in the crank register where the torque convertor snout sits. you may more than likely need to trim about 3/8" off the end of the input shaft , easy to do wit ha whizzer wheel just cover the trans well and wrap tape around the end of the bearing retainer to keep that area clean.
Napa used to sell a bearing that would fit the unfinished cranks but the time I tried to buy one it was not the correct part ???
Re: 440 crank? [Re: Lawn Monkey] #1043596
07/31/11 08:25 AM
07/31/11 08:25 AM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
Yes It is easy enough to do now with the crank out of the motor. there is a hole there but not the right size. easy machine shop job now.
Re: 440 crank? [Re: JohnRR] #1043597
07/31/11 09:47 AM
07/31/11 09:47 AM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
BCA/National FC69907 is the number and I paid $12 for the last one I got. Passon's and Brewer's have a bearing also $18.
My 72 440 was out of a Big Chrysler, Steel crank and it was drilled for the regular bushing. I thought most Steel Cranks were? I know the Cast ones are not unless they are out of something with a 4-speed.
Re: 440 crank? [Re: bumps440] #1043598
07/31/11 01:55 PM
07/31/11 01:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Depends on the crank. My cast 440 crank is not drilled at all.
Re: 440 crank? [Re: DaytonaTurbo] #1043599
07/31/11 02:10 PM
07/31/11 02:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive got a Imp crank in my 440.It was drilled.It seems they were hit and miss.Some are some arent behind autos.Like said crank out its an easy fix.Rocky
Chrysler Firepower
Re: 440 crank? [Re: therocks] #1043600
07/31/11 06:26 PM
07/31/11 06:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Don't confuse "drilled" with drilled to the correct size, most all forged cranks were drilled .915" but not all were finish sized .938" for a bushing.
