Who's the guy here that's done a bunch of 5.7 swaps? #1043103
07/30/11 12:35 PM
07/30/11 12:35 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline OP
JDMopar  Offline OP
I forget who,but just wanted to find out because I hope to swap yesterdays 5.7/545 score into a 70 Duster. I know he has done several of these swaps, and knows a lot of the do's and don'ts. Thanks.
Re: Who's the guy here that's done a bunch of 5.7 swaps? [Re: JDMopar] #1043104
07/30/11 06:31 PM
07/30/11 06:31 PM
JDMopar Offline OP
JDMopar  Offline OP
Re: Who's the guy here that's done a bunch of 5.7 swaps? [Re: JDMopar] #1043105
07/30/11 07:05 PM
07/30/11 07:05 PM
Arizona
410mopar Offline
410mopar  Offline
Arizona
I did a 5.7 truck motor in a hot rod with a small block 727 trans & converter. Mopar intake manifold with 750 Holly. MSD Hemi-6 ignition box and harnes.Mopar A/C delete pully. Fabricated a special aluminum oil pan.
Re: Who's the guy here that's done a bunch of 5.7 swaps? [Re: 410mopar] #1043106
07/30/11 09:55 PM
07/30/11 09:55 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I have looked into this a bit earlier and you may need a wiring harness from Hotwire Auto, TTi headers/motor mounts (unless you want to fabricate them), I know you can bolt one into a 727 or 904.
Well anyway, here is a tech article about a swap into an E-body:
https://board.moparts.org/ubbthreads/show...e=4#Post3930520
And here is another article I found:
http://www.carcraft.com/techarticles/ccrp_0905_hemi_engine_swap_guide/index.html
Re: Who's the guy here that's done a bunch of 5.7 swaps? [Re: MuuMuu101] #1043107
07/31/11 11:58 AM
07/31/11 11:58 AM
JDMopar Offline OP
JDMopar  Offline OP
Thanks MuuMuu. I looked at the links, and the Street & Performance site was a lot of help. I was able to find links to a thread where a Moparts member stuck a new Hemi in a Demon, and made the factory LX exhaust manifolds work.
Re: Who's the guy here that's done a bunch of 5.7 swaps? [Re: JDMopar] #1043108
07/31/11 12:06 PM
07/31/11 12:06 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
I was looking into doing the swap a while back and found this site useful: http://www.thehemi.com/newhemiswap.php
It has links to others that have done this already. I decided to not do it as $$$$ even though it would look fantastic. Good Luck.
1979 Chrysler 300 1968 Barracuda project
Re: Who's the guy here that's done a bunch of 5.7 swaps? [Re: JDMopar] #1043109
07/31/11 01:24 PM
07/31/11 01:24 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
JD, Daniel Jones has done a couple that I know of... He should be able to help you. He is Ebodyproducts on here... Hope this helps!
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
