5.7 Hemi with 545 auto in musclecar
#1043088
07/30/11 12:31 PM
07/30/11 12:31 PM
Posts: 8,485 Candler,NC / Myrtle Beach, SC
JDMopar
Has anybody done this swap? I got a smokin hot deal on an 06 5.7/545 combo out of a Magnum with 6k miles. I'd like to put this in a Duster that I have, but TTI doesn't offer headers for this cause the starter is on the passenger side. I want to use the 5 speed automatic, and know that I need to use one from a 2wd truck to get the slip yoke. Anybody got any ideas? I've got the stock manifolds, but don't want to have to notch frame rails to make them work. I know, I know.....want in one hand and crap in the other, and see which one fills up first! Any help or ideas appreciated.
Re: 5.7 Hemi with 545 auto in musclecar
[Re: JDMopar]
#1043089
07/30/11 01:52 PM
07/30/11 01:52 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
I would just use a SB 727 or a 904 Jackie; the tunnel is going to need too much work to get the 545 to work plus youre limited to an aftermarket floor shifter. The bolt pattern is the same and a dealer or aftermarket programmer can block out the transmission program in the PCM.
There are headers out there ($$$) but if you have a manual steering box the stock manifolds should work; I think guys are using Jeep Grand Cherokee manifolds to make the 5.7s work in A Bodys but I bet the LX manifolds would work too.
I want to do the same swap in my Satellite if I could find a complete setup at a decent price.
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: RangerDan440]
#1043090
07/30/11 02:03 PM
07/30/11 02:03 PM
JDMopar
Thanks Dan. I don't care to hack up the tunnel to make it work with the 545. It's a /6,3 on the tree body, so it ain't gonna hurt the value any! The thing I like about the 5 spd auto, is it already has the gear ratios designed for the 5.7...and I've already got it! If I can use the stock manifolds from the Wagnum that this Hemi came from, that would be great, as I have them too. I can make a Lokar cable work for the column auto shifter, but will have to mount an electric switch on the shifter handle to be able to manual shift it I think.
[Re: JDMopar]
#1043091
07/31/11 01:44 AM
07/31/11 01:44 AM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
First off..if the powertrain is out of a magnum, then it is not 545, LX never used the 545RFE It will be a W5A580(NAG) Trucks use a 545RFE, The RFE is a HUGE trans and will involve major floor surgury, tho it can be made "plug and play" with the correct use of electronics it is not just a simple drop in because of it`s size. I just went thru this mess and while you`ll see alot of talk, I only found one person in the country that has actually made a NAG work standalone and even He said it was "quirky". The OE controller CAN NOT be made to work by itself, It requires a aftermarket programmable controller. The NAG is very complicated (Electrically) to operate, due to it being a sequential automatic and having no direct input and output speed sensors it is impossible to monitor gear ratios so some "guessing" is involved when programming and the risk of the controller not knowing what gear it is in is huge. The owner of the project I was doing decided to not cut the floor and go a different route because this was a pristine low mile car. I Do have a 545 I need to sell now Rick
[Re: JDMopar]
#1043094
07/31/11 07:00 PM
07/31/11 07:00 PM
Blown71X
super gas
super gas
A tad North of Indy
If anybody cares, took these a little bit ago just so you know the difference. Left to right Small block 727, NAG, 545RFE And from the side Rick
[Re: JDMopar]
#1043096
08/01/11 12:17 AM
08/01/11 12:17 AM
Posts: 492 Kansas
BEINGmeISaCRIME
Kansas
If the insides of the 545 are as beefy as the outside, they ought to hold up fairly well!
Seen one of these give out at 60k in an 06 1500.
[Re: BEINGmeISaCRIME]
#1043097
08/01/11 03:38 PM
08/01/11 03:38 PM
Blown71X
super gas
super gas
A tad North of Indy
That is the exception, not the rule...The entire RFE series 45/545/68 has been a decent transmission, Yea I have seen them die but it is not a common problem. To date,I`ve done every single transmission to come thru this dealer since 1984 so i`ve been there and got the bad back to prove it. There was some problems early on with the accumulator retainer plate bolts breaking off on the valve body, but that was a fairly simple fix and didn`t involve pulling the trans.
Rick
[Re: Blown71X]
#1043098
08/01/11 10:46 PM
08/01/11 10:46 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Can't say about that config in an A body but here is how a 5.7 and a W5A580 out of an 07 Charger fits in a 70 GTX. I had a local drive line shop make a one piece drive shaft and a slip yoke. We turned a solid piece of aluminum to replace the rubber dampner. Yes, I had to cut the tunnel and raise it about an inch. Here is a link with tons of photos on the entire build so far. I do not have it running yet. My idea was to swap as much over as I could so I didn't have to reprogram or deal with the computer issues any more than absolutely necessary, haven't got to that point yet, the economy got in my way. http://www.forbbodiesonly.com/moparforum/showthread.php?t=1121
Driving modern convenience in classic beauty
[Re: MuuMuu101]
#1043102
08/02/11 02:32 PM
08/02/11 02:32 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
What about a 518OD? Is that any better than the 545? If you are going to have to massage the trans tunnel with either a 545 or a 518, and the 518 is better, you might as well go with that. Any input on the comparison of the 518 vs. 545?
Here is another picture of comparisons:
He said he wanted a 5-speed auto; not a 4-speed auto. I would do the 518 instead. Extra gear not worth the computer headaches.
