Radiator drivers lower exit 70 challenger??????? #1042737
07/29/11 06:55 PM
07/29/11 06:55 PM
Hr up from KCK
451 D*O*D*G*E Offline OP
Hr up from KCK
Got my aluminum water pump housing from Mopar Performance i guess they only offer it with drivers side outlet?My radiator is a pass side 4-row like brand new.What radiator do i need?Besides the obvious fact a drivers lower tube.What do i order it for?
Thanks for any help.Always something
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: Radiator drivers lower exit 70 challenger??????? [Re: 451 D*O*D*G*E] #1042738
07/29/11 07:54 PM
07/29/11 07:54 PM
get an iron housing but you'd add the weight. have a rad shop solder an outlet on the other side if there's room. Someone has an alum housing w the inlet on the pass side. Diff rad but w it being near new if it fits well I'd want to keep it
Re: Radiator drivers lower exit 70 challenger??????? [Re: RapidRobert] #1042739
07/30/11 11:48 AM
07/30/11 11:48 AM
Hr up from KCK
Hr up from KCK
What is the factory app that Mopar offers this drivers only oulet alum pump?If all the old cars were on the pass side why did they make this cast to the drivers side?
I can braze maybe i'll tackle it myself.Not a total loss just trying to understand the application.Thanks for the reply
Re: Radiator drivers lower exit 70 challenger??????? [Re: 451 D*O*D*G*E] #1042740
07/30/11 12:00 PM
07/30/11 12:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Any 1972 thru 1972 B or E-body big block radiator will fit.
As far as I know NO radiator had the pass side lower inlet until about 1973 or 74 .
The only 1970 E-body V8 radiator with a pass side lower is small block
These are both pics of factory housings for 1970
Re: Radiator drivers lower exit 70 challenger??????? [Re: gtx6970] #1042741
07/30/11 12:03 PM
07/30/11 12:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2
Re: Radiator drivers lower exit 70 challenger??????? [Re: gtx6970] #1042742
07/30/11 01:54 PM
07/30/11 01:54 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you want to keep your radiator 440 Source sells a passenger side outlet pump housing...
Re: Radiator drivers lower exit 70 challenger??????? [Re: 1_WILD_RT] #1042743
07/31/11 01:47 PM
07/31/11 01:47 PM
Hr up from KCK
Hr up from KCK
No i like the Mopar housing expecially after reading about the botched casting and quality of the china housing,thanks though.Ok my engine block is a 75 400 block so that explains the fact they may have built around the fact its a 400,and was a stock 400 in the car before it was a 451.Thanks for the info
Re: Radiator drivers lower exit 70 challenger??????? [Re: 451 D*O*D*G*E] #1042744
07/31/11 01:55 PM
07/31/11 01:55 PM
Indiana
O
Osyman Offline
Osyman  Offline
O
Indiana
I got a passenger side exit pump housing if you need it. I put it on and had the engine in before I realized what it was lol.
