Stuck brake drum - any tricks #1042453
07/28/11 11:41 PM
07/28/11 11:41 PM
Missouri
convertriple Offline OP
super gas
super gas
Missouri
i have a 70 Challenger which hasn't moved in 15 years, but now must get rolling. I am trying to get one of the rear drums off, but it is stuck and won't rotate or come off the axle. Because it won't rotate I'm guessing that the drum is rusted to the pads.
I have tried beating on it with a hammer, prying on it, pb blaster all around and inside, but I'm about out of ideas.
Anyone got a trick to share? I have a torch, but am unsure of where I should direct the heat since it won't rotate.
Re: Stuck brake drum - any tricks [Re: convertriple] #1042454
07/28/11 11:56 PM
07/28/11 11:56 PM
NY NY
3
340duster340 Offline
NY NY
if you torch it, heat the outside of the drum where the pads would be.
You could also try making a puller the grabs the edge of the drum and pushes against the axle register.
I have also had good results using a slap hammer
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Stuck brake drum - any tricks [Re: 340duster340] #1042455
07/29/11 12:06 AM
07/29/11 12:06 AM
IN
ahy Offline
ahy  Offline
IN
Different vehicle, same problem. I did not want to beat on it so hard it hurt the wheel bearings. Gentle heat (propane) did not help. I ground two clean spots on the outside of the drums and welded sections of 3/8" rod as cleats. Then used a good sized gear puller on the cleats and axle to get the drums off. Worked like a charm. Tension on the puller plus a hammer blow broke it loose. New drums required however.
Re: Stuck brake drum - any tricks [Re: ahy] #1042456
07/29/11 12:41 AM
07/29/11 12:41 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Worse case, near the outside edge , cut a circle in the flat center out of the drum with the torch, the center will turn then and outside can be stationary.
Did you try to adjust the shoes smaller thru the window in the backing pad?
I have taken some stubborn ones off, the Nails to retain the shoes can be cut or will break when taking them off.
Re: Stuck brake drum - any tricks [Re: convertriple] #1042457
07/29/11 01:52 AM
07/29/11 01:52 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Open up the wheel cylinder bleeder or cut the brake line to allow the wheel cylinder to contract, and turn the adjuster back.....get a bigger hammer/sledge
MikeR
Re: Stuck brake drum - any tricks [Re: A12] #1042458
07/29/11 02:01 AM
07/29/11 02:01 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Do not use a gear puller etc. You will destroy the druwm.
Ensure the adjusters are retracted as far as possible
Remove the hydraulic line from the wheel cylinder
Unbolt the wheel cylinder from the backing plate
Use a die gridner and cut off the heads of the anchor pins
With the pins free, you should be able to pull the drum off even if the shoes remain hung up. the shoes will come with the drum.
Astrobuf
So, are you really a Rocket Scientist?
Re: Stuck brake drum - any tricks [Re: astrobuf] #1042459
07/29/11 10:18 AM
07/29/11 10:18 AM
Andrewh Offline
Andrewh  Offline
yep, cutting the pins is the easiest. it will fold the shoes as you pull because of the springs.
you don't need a die grinder though.
a screw driver will get under the pins, and you can grab them with plyers to pull them out far enough to cut them with something.
done it a couple of times.
Re: Stuck brake drum - any tricks [Re: Andrewh] #1042460
07/29/11 10:27 AM
07/29/11 10:27 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I moved a shorty Travco a couple of years ago that had this same issue. And those are HUGE drums.
I just rocked it back and forth using a HD towing strap.
Re: Stuck brake drum - any tricks [Re: convertriple] #1042461
07/29/11 02:03 PM
07/29/11 02:03 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Jack it up,take the wheel off,run the rpm's up and hit the brakes a few times.
Re: Stuck brake drum - any tricks [Re: 62maxwgn] #1042462
07/29/11 02:19 PM
07/29/11 02:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Try to rap the out face of the drum with a hammer to retract the shoes.
Re: Stuck brake drum - any tricks [Re: MoparforLife] #1042463
07/29/11 07:04 PM
07/29/11 07:04 PM
Hr up from KCK
451 D*O*D*G*E Offline
Hr up from KCK
I was scrolling waitin for someone to say undo the lines(cut)whatever unbolt cylinder and chisel off pin heads(or grind)..shoes are rotten anyway and those parts are all cheap.Save the drum!
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: Stuck brake drum - any tricks [Re: 451 D*O*D*G*E] #1042464
07/29/11 11:44 PM
07/29/11 11:44 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Jack it up safely and drop the driveshaft. After you have the other drum off and soaked everything with penetrating oil and cut off the locating pins, put a big MF pipe wrench on the rear yoke and twist and break the shoe loose... a variation of what those said to fire the engine and put it in gear.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Stuck brake drum - any tricks [Re: convertriple] #1042465
07/30/11 12:43 AM
07/30/11 12:43 AM
Missouri
super gas
super gas
Missouri
Thanks for the suggestions. The car doesn't run, I'm trying to get it ready to sell and want it rolling so that I can get it on a buyers trailer.
I will try cutting the pins first, and go from there with some of the suggestions. We'll see what works.
Re: Stuck brake drum - any tricks [Re: convertriple] #1042466
08/08/11 10:49 PM
08/08/11 10:49 PM
Missouri
super gas
super gas
Missouri
An update - The last two drums came off after I brought out a sledge hammer. Thanks for the help
Re: Stuck brake drum - any tricks [Re: convertriple] #1042467
08/08/11 11:01 PM
08/08/11 11:01 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Did the drums break apart, or did the shock get them off intact?
Regardless, you now have it rolling!
Re: Stuck brake drum - any tricks [Re: GO_Fish] #1042468
08/09/11 12:29 AM
08/09/11 12:29 AM
Missouri
super gas
super gas
Missouri
Drums came off intact, just pulled out the guts and put the drum back on. It is great to have it rolling, and soon out of the way , too bad I blew a brake line on my 95 Ram backing up to it to pull it! Now I'm having fun trying to break loose rusty brake fittings!
gotta love it.
Re: Stuck brake drum - any tricks [Re: convertriple] #1042469
08/09/11 01:17 AM
08/09/11 01:17 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Let me guess, it blew behind the gas tank, and the fuel line made in stainless looks like new..
I think I cut the line by the rear fitting and used a 6pt socket to get the old fitting loose.
I bent a couple of lengths of straight line and a union to repair mine. Started at the rear and worked forward..
Congrats on getting the drums off.
Re: Stuck brake drum - any tricks [Re: sthemi] #1042470
08/10/11 12:20 AM
08/10/11 12:20 AM
Missouri
super gas
super gas
Missouri
Heck yes it blew behind the tank....again and yes the fuel line looks great!
This time I'm using the green/blackish coated lines. The coated line I put on the front lines a few years ago hasn't rusted at all, but the front to rear brake line I replaced a few years before that has gone out again. I wish I had known about the "coated" lines the first time around, because as I remember, I had to have it pressure bled to get the air out.
Re: Stuck brake drum - any tricks [Re: convertriple] #1042471
08/10/11 01:10 AM
08/10/11 01:10 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Are these rubber lines? I would make a heat shield or some kind of wrap to keep the heat off.
Re: Stuck brake drum - any tricks [Re: None2Slow] #1042472
08/10/11 10:55 AM
08/10/11 10:55 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
guys, do you know the durms assembly have a provision to release them from the adjusting rod on backing plate ?
